Z Proformance
Old Aug 29, 2002 | 03:36 PM
Ricky's Avatar
Ricky
Default Z Proformance
Okay so I jsut read Sport Compact, how come they only got 250hp out of the Z when it's said to get 287? Can it actually put out 287 hp?
Old Aug 29, 2002 | 03:57 PM
madmonkey's Avatar
madmonkey
Do a search and you will see that this is a matter of crank HP vs Rear Wheel HP.
Some power is always lost to the drivetrain. The numbers are reasonable
Old Aug 29, 2002 | 04:36 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Default Re: Z Proformance
SCC=Actual Rear Wheel HP
Nissan=Engine Crank HP
It's actually pretty impressive with 13% loss...
Old Aug 29, 2002 | 05:50 PM
Ricky's Avatar
Ricky
15% loss, and whats a crank hP vs. rear hp ?
Old Aug 29, 2002 | 06:00 PM
Wiley's Avatar
Wiley
Crank HP is the power the motor makes without any other factors involved, like if it was out of the car on an engine stand
Rear wheel HP is the MEASURED power the after having to turn the components of the drivetrian. The components like the clutch, transmission, driveshaft, axles, brake rotors and wheels all ROB power to be turned. They usually soak up about 15% of the motor hp
Old Aug 30, 2002 | 12:23 PM
morganjd's Avatar
morganjd
Z Proformance
I hate to be a dick, but learn to spell performance.
Old Aug 30, 2002 | 12:28 PM
ericn's Avatar
ericn
Default Those numbers can get better!
Parasitic loss can be reduce a little more by replacing tranny and differencial fluid with a high end synthetic. (Royal Purple etc...)
Depending on how the car was treated during breakin and the number of miles prior to the dyno, most cars perform better after a few thousand miles.
Just my 2 cents
ProForm
May 30, 2012 09:23 AM
thrill350z
Sep 5, 2006 04:04 PM
thrill350z
Aug 1, 2006 01:15 PM
Rahtok
North West
Sep 27, 2004 08:56 AM
