Automatic Shifting...Is it pointless???
Old Dec 10, 2009 | 11:22 AM
ms350z's Avatar
ms350z
Originally Posted by sucafish
Bonus question:
A friend of mine who seems somewhat knowledgeable said that manually shifting an AT causes undue heating resulting in less life in the trans. Any truth to this in your opinions?
There is some truth to this. Continuous levels of high heat are probably the number one killer of auto transmissions. If you are manually shifting your AT w/ the intent of holding it at a higher rpm for a longer period of time than what it would do in full AT mode, it will produce more heat and over time shorten the life of the transmission.
Old Dec 29, 2009 | 11:41 AM
sucafish's Avatar
sucafish
Default Retarded
So, it has been almost a month since my original post RE: the automatic/manual shifting of the Z. My what experience does. I not only love automatic/manual shift option, but it is the only way I drive it. Not doing so seems like a complete waste of car. I love this car and wish I could mate with it and make little Z's.......
Old Dec 29, 2009 | 01:20 PM
dhays's Avatar
dhays
If you are always using the manual shift option (again, this isn't manual shifting but is simply having you set the shift points) then it seems to be a waste of the auto? If you always want to determine your own shift points, then why not get a manual transmission and save the wear and tear on the auto?
I can see lots of situations where it would be nice to have an automatic. And with an automatic I can see some, rare, situations where it would be nice to use the "manual" feature. But to do it all the time seems pointless.
That's just me however.
Old Dec 29, 2009 | 01:25 PM
halfass872's Avatar
halfass872
Old Dec 29, 2009 | 03:22 PM
terrasmak's Avatar
No matter how you drive it, its still an automatic.
That means no man card unless your handicapped.
Old Dec 29, 2009 | 03:39 PM
z_mini's Avatar
z_mini
Look into getting Padel shifters, Much more fun. Can also be mounted on stock steering wheel.
Old Dec 29, 2009 | 04:51 PM
brandon3434's Avatar
brandon3434
ibtl
Old Dec 29, 2009 | 05:38 PM
Adrians07Z's Avatar
Adrians07Z
Originally Posted by kidrobot
3 words. valve body upgrade
+ 1
I felt the same way when I got my 07 Z .. just kept it in "D" b/c of the lag
I installed the valve body upgrade and that helped a huge amout with making shifts quicker and firmer
then upgraded the stock battery ground cable (installed JL amp / sub) .. that seemed to help the manual mode a good bit too along with the feel / response of the engine
go look at the stock ground wire .. then look at the positive wires .. huge difference
I installed two 4 gauge wires for the ground .. going to the stock location on the car (two 10mm bolts) .. then used a heavy duty terminal from the auto parts store .. think I spent about $12
Old Dec 30, 2009 | 07:06 AM
Harleyjacks's Avatar
Harleyjacks
I agree on the Valve Body huge difference and for me would never now even consider a Manual. The Car is tight now and I only every now and then use the shift mode for engine breaking only. I have a 2008 and it has had an ECU reflash as well as the GTM valve body upgrade. It’s now very quick off the line and pulls like mad. Me I’m 50 and I have had Manuals and Autos over the years and by far for this Car with the platform it sits on and engine coupled with a valve body upgrade gives you the best of everything in my opinion.
2008 mag blk Touring /stillen exhaust/stillen II CAI/ECU Flash/Rotora BBK all 4/Eibach Sways/GTM Valve Body
Old Feb 15, 2010 | 09:32 AM
z_mini's Avatar
z_mini
Just got mine done, made a big difference. Also got paddle sifters installed with tech light.
Old Feb 19, 2010 | 05:00 AM
Shane4367's Avatar
Shane4367
I only use my manual mode occasionally for fun, but it works great. If I use it at low rpm's it shifts slow and soft but at WOT it's very crisp and when I hit the shifts right (around 6100) it actually surges forward from 1st to 2nd and 2nd to 3rd. Also great for maintaining rpm's on winding roads (as others mentioned). For those who have done the valve body upgrade, what does that cost??
Old Feb 19, 2010 | 07:39 AM
winchman's Avatar
winchman
"That means no man card unless your handicapped."
I've had my man card for quite a while. Getting it didn't involve shifting gears. If that's part of the latest renewal test, I'm still good to go.
BTW, that should read: That means no man card, unless you're handicapped.
Old Feb 21, 2010 | 12:17 PM
SniperHunter's Avatar
SniperHunter
Whaaaaaat? That's sick. Come to one of the Great Neck meets on Wednesdays. I wanna' see the paddles!
Old Feb 21, 2010 | 12:57 PM
winchman's Avatar
winchman
I see the paddle shifters, but what's the silver thing with the yellow button and red strap?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
seagrasser
Oct 11, 2015 03:27 PM
Tylerx7z33
Sep 21, 2015 01:43 PM
