Disconnect negative terminal of battery....help
Old Nov 29, 2003 | 07:03 PM
momentum's Avatar
momentum
Default Disconnect negative terminal of battery....help
Hi everybody,
Need some information on disconnection of the negative terminal of the battery.
Have put the Z to sleep last month since our first major snowfall. Lowered both window down a bit as per advice by some members and then disconnected the negative terminal of the battery.
Then, I was reading the owners manual the other day on battery(yes, I know I should have read it before disconnecting the negative), and found some instructions on disconnecting and reconnecting the negative terminal. It outlines steps to be taken. It does not even talk about lowering down the windows. It also warns that if done improperly, both the window and the side roof panel may be damaged....
Does anybody know what exactly are the proper procedures for disconnecting and reconnecting the negative terminal of the battery without causing damages?
By the way, I have checked with the local dealer who could not give me any satisfactory answer.
Thanks.
Old Nov 29, 2003 | 07:25 PM
alphared's Avatar
alphared
me thinks you're over thinking it. just lower the driver window half an inch so that it doesn't hit the roof when you open or close it. remove the negative terminal and done.
Old Nov 29, 2003 | 07:42 PM
samw1978's Avatar
samw1978
I just remove the negative and put it back afterwards... no problem at all for my last 3 cars
m_0g
Jun 3, 2021 10:05 AM
Siqcology
Sep 18, 2019 01:45 PM
OdesiTT
Sep 30, 2015 10:47 AM
TrackFiddy
Sep 24, 2015 11:40 PM
Beater350z
Sep 9, 2015 03:36 PM
