Choices choices choices
Old Aug 31, 2011 | 09:16 AM
Junkster's Avatar
Junkster
Originally Posted by ZJoe
Invest in suspension components OTHER than coil overs. Ajustable upper control arms, rear camber arms, toe bolts, maybe some bushings if you need them. Get the suspension ready ahead of time for coilovers, wheels and a drop. Most people get coilovers first and don't think of the other things needed when you drop a car then ***** when their tires are wearing uneven and/or their bushings go out.
That or buy some stickers and fuzzy dice and put the rest in an emergency maintenance fund.
This makes no cents...
just cause you have coilovers doesnt mean that your alignment cant be set to "spec"...if your THAT worried about alignment specs than adjust your coilovers so that your not that low...simple as that...
You should be able to lower the Z about an ~inch or so all the way around and still retain stock alignment specs....
Regardless, you can run quite a bit of camber before you start getting un-even tire wear...99% of excessive wear is as a result of toe being off, and that can be fixed for less than 100 bucks if you buy toe bolts (provided that your that low to begin with)...
Old Aug 31, 2011 | 10:16 AM
ZJoe's Avatar
ZJoe
Just because he "should" stay in spec with a 1" drop doesn't mean he will. I thought the same thing and then found out the hard way that "should" doesn't always translate to "will". Sooner or later, you change one thing on the Z suspension, you wind up having to change three more things to compensate.
In that case he should just get springs and forget about it.
Old Aug 31, 2011 | 10:19 AM
ZJoe's Avatar
ZJoe
Btw, I saw the 510 in your album. Gorgeous car
Old Aug 31, 2011 | 12:19 PM
Bmurray350z's Avatar
Bmurray350z
Get a tune.
Old Aug 31, 2011 | 12:20 PM
NZMOWND's Avatar
NZMOWND
Originally Posted by Junkster
This makes no sense...
fixed that for you...
Old Aug 31, 2011 | 12:44 PM
Pengu's Avatar
Pengu
Ended up doing an additional $500 for my next car payment so $700 this month total. Then new rear tires in preparation for the winter. And a little bit of money to fix some odds and ends that needed some love.
Hope the 350Z community will respect my decision. If not oh well :P
Old Aug 31, 2011 | 01:05 PM
terrasmak's Avatar
Great idea, tire will set you back around another $300 , leaving you with potentially $300 more to spend. Save it for a rainy day.
ZJoe's Avatar
ZJoe
You have done well young one.
Old Aug 31, 2011 | 05:02 PM
JedixSole's Avatar
JedixSole
Originally Posted by Duckeee
rims + stock height = failzzz
get coilovers, or at least springs, then get wheels..
Old Aug 31, 2011 | 10:17 PM
J 0 K 3 R's Avatar
J 0 K 3 R
i still think your high rollin G-ma want sum shany reeims'! :P
Old Aug 31, 2011 | 10:28 PM
pcressey's Avatar
pcressey
You have chosen... wisely.
Old Sep 1, 2011 | 07:50 AM
Junkster's Avatar
Junkster
I think this is a matter of self control more than it is about practical application lol...
I agree though, but not everyone can afford to buy coilovers, front upper arms, rear camber arms and toe bolts, sway bar endlinks, bla bla bla all at once. Which in that case there is nothing wrong with buying coilovers and doing a moderate drop...then if you want save up for the rest in preparation for what your "goal" is with the car. IMHO coilovers take up the cake as far as the bigger ticket item, hence why i voted coilovers...then again to each their own...
I know this topic has been beaten to deafff enough to realize its more of a personal preference!
Thanks
lol i did that on purpose!
OP: Good choice! Im sure thats a way more responsible decision than what 90% of people would have picked lol...and that includes me!
Old Sep 1, 2011 | 08:41 AM
Itzcashew's Avatar
Itzcashew
How about save it all.for school
dfresh713's Avatar
dfresh713
Master
Put the money towards paying off your car or for any repairs/maintenance.
Old Sep 1, 2011 | 10:51 AM
VO...'s Avatar
VO...
Administrator
You did well!
Old Sep 1, 2011 | 11:37 AM
kbro's Avatar
kbro
You already have nice exhaust, mind as well take full advantage of it and get osiris. Before I got osiris my A/F ratio was all over the place and my HP/TQ curves were all but smooth, now A/F is spot on and hp curve is where it is supposed to be. I do not have a copy of my chart on this computer, otherwise I would post it.
Good luck with your choice!
Old Sep 1, 2011 | 12:15 PM
NZMOWND's Avatar
NZMOWND
the choice has been made a few post up... READ
Old Sep 1, 2011 | 12:16 PM
  #38
soporific88's Avatar
soporific88
Do something nice for your Grandma.
Old Sep 1, 2011 | 12:19 PM
  #39
NZMOWND's Avatar
NZMOWND
apparently its cool not to read the whole 2 page thread...
Old Sep 1, 2011 | 01:33 PM
  #40
Junkster's Avatar
Junkster
so not cool breh...get with the program!
