No Problems - Other Than the Sucky Bose System!!!
I would like to report I have not experienced any of the previously reported problems other than that the Bose system sucks big-time! Now if Naim Audio only made car audio.
On a different note, I did get a "Serice Engine Soon" light due to NOT properly tightening the gas cap. If you do not hear at least 3 click when tightening your gas cap you may find yourself with this light on. Also when thew gas pump stops, DO NOT try and top-off the tank. This is a known issue with Nissan. When the pump stops than your tank IS FULL.
Silverstone - Touring - MT
relldog
relldog
relldog
relldog
Also, what happens if you DO try to top off the tank?
Thanks,
Todd
I had to bring it in. Very fast! Quick diagnostic. But be warned the techs have very little experience with the Z.
I guess this is very common with current Nissans.
relldog
relldog
In most cars today, a loose gas cap will trigger the check engine light. In most cars, this light will go off after tightening the cap and after about 1 tank of gas. If you disconnect the battery, the light should also reset, but I don't recommend this.
