Oil Filter Short or Long??
Originally posted by Eagle1
Try the Mobil 1 M108 or the slightly longer M110. I use the M110, and you can get it at Autozone.
only use the long ones. like the: 9E000 (if you go with OEM)
Otherwise, everyone recommends the Mobil 1 M110. The M110 is the best from Mobil. some also use the M105, but the 110 is probaby the better way to go.
avoid the crappy Fram filters with cardboard in them.
Just so you know... the shorter OEM ones are poorly constructed and use cardboard end caps... the lowest of the low, IMO. The longer OEM filter has better construction , but the filter media is still paper. I took both apart and have pics that illustrate my point well. Go with Mobil 1 filters. I use the M1-110.
Mika
Mika
i remember when i used to surf the prelude forums, someone did a oil filter shootout with various brandds. here are his feedbacks.
http://www.ntpog.org/reviews/filters/filters.shtml
Originally posted by maximumsportZ
anyone?
anyone?
If you go to a bypass filter set up, then you need to add a quart to handle the additional size of the large separate filter.
