Having trouble with heel-toe in the Z
Old Aug 29, 2012 | 08:41 AM
Rex08Z's Avatar
Rex08Z
Default Having trouble with heel-toe in the Z
I know this is probably a done to death topic but from the responses I've read, people usually say that the accel pedal(edit - sorry tired) is too small so they get a custom one. That's not my problem, my heel is angled directly over the accelerator as it is, but either I try to blip it a bit and there's nothing there because it's recessed, or I try a committed hard blip, and tap the recessed pedal but actually get my heel stuck on the center console, all of the time. This feels like a major roadblock in my learning to drive better. I don't think hitting your heel against the console is a natural problem so what am I doing wrong here? Does anyone else have this exact problem? My foot isn't even that big!
Old Aug 29, 2012 | 08:57 AM
Jagerz's Avatar
Jagerz
Try angling your foot less and rotating your heel down to catch a slightly lower part of the throttle. Before I had pedal covers, I only needed a slight movement to catch the edge of the gas pedal. Never came close to the console. Now with pedal covers I dont even have to swing my heel out, I can use the right ball of my foot to blip the throttle. I would recomend at least some pedal covers though... its a night and day difference.
xecksx58's Avatar
xecksx58
I can't "heel toe" with my normal sneakers on, but barefoot I can do it like a champ.
If I have my sneakers on I "ball toe" (as I like to call it) where I use my toe to blip the throttle and the ball of my foot on the brake, rolling my foot onto the accelerator.
Off topic: where from NY are you?
Old Aug 29, 2012 | 09:02 AM
terrasmak's Avatar
380RS pedal helps a bit, its available at www.nissanraceshop.com , talk to Scott. I installed that and bent my throttle pedal over closer to the brake pedal.
Old Aug 29, 2012 | 09:17 AM
Duckeee's Avatar
Duckeee
calm down with that super angle or try moving your foot to the left on the brake pdeal more. you only need a little contact pitch with the gas pedal.
floor mounted pedals like in porsches and bimmers i have trouble with.
Old Aug 29, 2012 | 09:49 AM
Rex08Z's Avatar
Rex08Z
Never driven one of those before, but I'm a sim racer and my pedals are floor mounted. That must be why I do it.
Old Aug 30, 2012 | 12:28 AM
Rex08Z's Avatar
Rex08Z
To think that the solution was this easy, I feel silly.
My car's pedals:
My sim's pedals:
Do you see it now? I learned heel toe with racing sims before even driving my car. But the difference is clearly the brake being more over the left in my sim racing, so I'm used to pressing there and angling my foot more.
Old Aug 30, 2012 | 02:10 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Wait one ******* minute...........your are a sim driver, now a real life driver?
More seat time, driver position, seatbelts and learn your real ******* car! Size twelves and I can down shift/heel toe two gears into corners I know by heart. It's experience on top of being secured in the car...also not being afraid to smash the brakes.
Now while in a video game you can exercise technique to the t. Real life you have way more variables! Surface, tires, car's suspension, and your driving ***** in real life might be smaller. So diving into the corner in GT5 is über easy, same corner in real life comes with the harm factor to you or your car!
Also trail braking, heel toe, rev matching, and any other technique you are trying to execute. Needs to be on the same corner or similar corner to improve the end result.
Anyways funny you asked, and compared it to a simulator...
Old Aug 30, 2012 | 05:23 AM
Syner's Avatar
Syner
I use the ball of my foot higher on the brake than normal and a shallow angle to catch the edge of the gas pedal with my heel. I don't over-emphasize the angle...
Old Aug 30, 2012 | 08:49 AM
Rex08Z's Avatar
Rex08Z
No. All I was doing was practicing race driving techniques in the game, especially things like heel toe and trail braking, before I attempted them in a real car. When I first got my Z, I could actually heel toe with my smaller dress shoes, but since I started wearing sneakers, my heel was getting caught on the console.
Anyway, yes GT5 actually taught me some high level racing skills that I have yet to try out on my real car, but I know the motions now. Of course I need more seat time, but consider the game as image training, which a lot of drivers do, for mental preparation.
Old Aug 30, 2012 | 09:27 AM
Sylvia Zcarr's Avatar
Sylvia Zcarr
Practice more of a 'roll' of your foot to the right and not 'pressing down' with the heel.
Works for me...
Old Aug 30, 2012 | 09:37 AM
zakmartin's Avatar
zakmartin
I'm with KingBaby on this one. This is absolutely HILARIOUS!
Old Aug 30, 2012 | 09:40 AM
2TH PWR's Avatar
2TH PWR
uh dont know if this helps. but for me I just had to position the ball of my foot higher on the brake pedal. Once I learned this it was easy.
This is a cam from my first track test....
Old Aug 30, 2012 | 10:33 AM
Rex08Z's Avatar
Rex08Z
If I learned it with a gamepad before driving, I could understand what might be funny, but I have actual pedals, a racing seat, a gated shifter and...you're going to laugh even harder, aren't you?
Old Aug 30, 2012 | 11:11 AM
Voboy's Avatar
Voboy
Get a shop to create some aluminum plates to stack and bolt on top of the pedal to "raise" it for your needs? Make sure its not heavy enough to preload the gas though.
Old Aug 30, 2012 | 12:23 PM
JedixSole's Avatar
JedixSole
if you know how to c-walk then you can do this.
Old Aug 30, 2012 | 12:28 PM
KingBaby's Avatar
KingBaby
Hardest Setting
What's your PSN tag?
2TH PWR, Sylvia Zcarr, Syner, terrasmak, Duckeee gave great answers..
Old Aug 30, 2012 | 12:36 PM
JedixSole's Avatar
JedixSole
i learned driving from Initial D. battle level 24. swag.
Old Aug 30, 2012 | 01:23 PM
freddys 350z's Avatar
freddys 350z
Z1 avt pedals. They helped me a lot.
Old Aug 30, 2012 | 01:28 PM
Rex08Z's Avatar
Rex08Z
psn: Romeo_Echo_Xray.
I'm thankful to them also.
