accidently shift !!.. help me out
Old Nov 18, 2012 | 11:39 PM
superxcat's Avatar
superxcat
Default accidently shift !!.. help me out
im a manual driver for 2 days since i just got it yesterday and i was on my way to the gas station at local for abt 25. i wasn't payin attention to the rpm and barely the speed, i just shift when i feel like i need to. i was at 2nd gear and want to shift to 3rd gear, so i push the clutch and shift to 3rd and when i step on the gas , i figure the loud noise is not right , so i immidiately push back the clutch and shift to neutral then shift to 3rd just to make sure im in the correct gear. i wonder if a miss shift like the one im doing today is gonna break the car or not. im kinda worry if i do it again at freeway now since its a high speed.
Old Nov 19, 2012 | 12:02 AM
logan09's Avatar
logan09
wow. I cannot comprehend what you are saying at all. Grammar is your friend as well as punctuation.
Old Nov 19, 2012 | 12:07 AM
superxcat's Avatar
superxcat
basically i shift to 5th gear instead of 3rd at speed 25. and i wonder if it going to break my car.
Old Nov 19, 2012 | 01:04 AM
BlackFaytZ's Avatar
BlackFaytZ
sounds like a gear grind. It probably was not in gear all the way, when you stepped on the gas. It would of happened anyways if you were almost into third gear..
Anywhos practice driving manual, preferably on another car if you don't want overhaul you transmission anytime soon..
ohs you will need to learn quickly too.. You're in SF, GAWD DAMN inclines are scary..
Old Nov 19, 2012 | 04:01 AM
pro_350z's Avatar
pro_350z
+1 Just keep practicing cause the car basically drives itself
Old Nov 19, 2012 | 04:16 AM
JCITY's Avatar
JCITY
Cool You what?
Not a good idea my friend.Being in 5th gear at 25 will lug your engine.
Sure,it will drive.Long term you with this and other stuff you are doing
you may be heading to the tranny shop in the near future.
Practice...
Old Nov 19, 2012 | 04:33 AM
PerfZ's Avatar
PerfZ
You did not hurt a thing if you went to 5th gear and lugged it a bit. Didn't hurt much if you ground the gears by mis-shifting either, most of us have done that once or twice, I'm guessing. But long term it is not recommended for either.
Old Nov 19, 2012 | 05:26 AM
Godzirrra922's Avatar
Godzirrra922
Good God man, is your first language English? If so...then just wow. GRAMMAR! But anyway, I'm guessing (from that jumbled mess of words you wrote) that you didn't depress the clutch all the way, or let the clutch out too soon before you were in gear. Just keep practicing, and you'll be driving your Z fine in no time.
Old Nov 19, 2012 | 12:20 PM
aleemotorsports's Avatar
aleemotorsports
The car will be fine, just try not to make a habit of it...everyone has to learn at some point in time, however I might consider learning the fundamentals of how to actually drive a manual first before beating on your car to hard.
Best of luck and enjoy the new car.
Old Nov 19, 2012 | 01:03 PM
JeffJohnries's Avatar
JeffJohnries
Car is FCUKED... sell it asap
Old Nov 19, 2012 | 08:15 PM
blastoff99's Avatar
blastoff99
Learning to drive a MT Z in San Francisco. Nice.
No, the loud noise is not right. That's a little worse than just missing the shift from 2nd to 3rd and finding 5th instead.
Old Nov 19, 2012 | 10:31 PM
terrasmak's Avatar
2nd to 5th will cause no damage, he'll I usually shift from 2nd to 4th and 4th to 6th. If you miss shifted and found neutral, you jut revved it while not in gear, no big deal either.
Old Nov 20, 2012 | 08:27 AM
blastoff99's Avatar
blastoff99
I agree that 2-5 will cause no damage. But 'loud noise' to me would mean some sort of unusual noise, not just the sound of the engine revving in N. Maybe the OP doesn't know the difference or can't describe the difference between a revving engine and grinding gears.
Old Nov 20, 2012 | 08:33 AM
Junkster's Avatar
Junkster
The only way to fix/reverse the damage is to do the opposite:
1) get on the freeway and reach freeway speeds (60-70 mph)
2) Make sure your in 5th gear (the gear you miss shifted on the first time)
3) push the clutch in and shift to 2nd gear
4) let go of the clutch and floor it
This should save you plenty of money on repairs
Old Nov 20, 2012 | 08:50 AM
Bruno350z's Avatar
Bruno350z
OP you sure you didn't **** from 2nd to 1st which would cause the rpm's to spike, resulting in a loud engine noise? lol
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
Mattg350z
Oct 2, 2015 06:51 AM
