Z drivers, which display do you put on the first gauge from the left?
Old Dec 24, 2012 | 02:38 AM
JCITY's Avatar
JCITY
Yes,VERY random.
You must have time on your hands.
Is this a follow up question of a post awhile back,
"whats the first thing you do when you get in your car"?
OUTSIDE TEMP
Old Dec 24, 2012 | 06:11 AM
muffles's Avatar
muffles
I put it on outside temp to help me adjust the in car temp on the dials further down!
Old Dec 24, 2012 | 06:38 AM
winchman's Avatar
winchman
Why would you need to know the outside temp to adjust the inside temp?
Old Dec 24, 2012 | 06:46 AM
ParanoidAndroid's Avatar
ParanoidAndroid
I drive it with outside temp.
Old Dec 24, 2012 | 06:48 AM
RedLine_ZR's Avatar
RedLine_ZR
speed all the time. look at the speed here most of the time
Old Dec 24, 2012 | 06:51 AM
MWallace's Avatar
MWallace
Between Speed and Temp
Old Dec 24, 2012 | 06:53 AM
shine-EZ's Avatar
shine-EZ
Summer- speedo
Winter- temp is default on KOER, then once I get going switch n look at tires, then speedo
I use the tach constantly, rarely look at analog speedo (useless) imo.
Old Dec 24, 2012 | 07:03 AM
sportbiketed's Avatar
sportbiketed
I used to leave it on speed, now it's getting replaced by oil or water temp.
Old Dec 24, 2012 | 07:13 AM
350zsunshinefl's Avatar
350zsunshinefl
MPG lol.
Old Dec 24, 2012 | 07:19 AM
daytonabluez05's Avatar
daytonabluez05
Outside temp
Old Dec 24, 2012 | 07:20 AM
CourtesyFlush's Avatar
CourtesyFlush
speedo for sure, is there a way to set it so you don't have to change it every time?
Old Dec 24, 2012 | 08:16 AM
terrasmak's Avatar
Mpg on the street , and I usually swap to speedo at the track
Old Dec 24, 2012 | 09:10 AM
red roadster's Avatar
red roadster
Pretty much stays on temp but I do scroll through it to check tpms and mpg.
Old Dec 24, 2012 | 09:47 AM
Waiz's Avatar
Waiz
I always leave it on the speedo since I don't like the position of the speedo on the dash
I find it actually helps to keep me within the posted speed limit since it's an exact number
Old Dec 24, 2012 | 10:54 AM
AKphoto's Avatar
AKphoto
Always leave mine on Speedo, as my analog speedo reads fast by like 6 mph...
Old Dec 24, 2012 | 03:08 PM
silverstone914's Avatar
silverstone914
speedo, even though the annoying *** thing always goes back to temp when its below a certain temp (30 i believe)
Old Dec 24, 2012 | 05:30 PM
archangele's Avatar
archangele
alternate between MPG and outside air temp
Old Dec 24, 2012 | 05:36 PM
  #38
Houston Z33's Avatar
Houston Z33
Speedo for me, I'm also hooked on the Digital Speedo because the Analog Speedo is a little hard to read.
I wanna break myself of this habit ASAP, 370's have a clock in that position now (wtf Nissan?!)
Old Dec 24, 2012 | 05:56 PM
  #39
muffles's Avatar
muffles
Well, it's because the heat/cold system seems to work "harder" the bigger the temp differential between the current and desired (internal) temp.
If I haven't used the car for a while I can assume (or at least use as guidance) the inside temperature is the same as the outside temp.
Which means I can just put the temperature control dial to a suitable value instead of waiting a minute or two and realising if it's substantially different to my desired temp.
In practice that means if it's particularly cold I can see how cold and turn it up to a higher than normal temperature so it gets to my desired temp quicker. Otherwise I have to fiddle about with it a minute later (while driving, probably)
Old Dec 24, 2012 | 05:58 PM
  #40
muffles's Avatar
muffles
Oh, also it helps me learn Fahrenheit as I'm not from the US!
