Sharing some mild my mods by pics
Old May 20, 2013 | 10:02 PM
  #81
silvertouringz's Avatar
silvertouringz
Originally Posted by 350Zdj
Mabrook with the new parts man!
I've lovin that paddleshift setup! Care to share where can we get those from?
Thanks dude, these paddle shifter are off a JDM 350GT-8 which was imported by a junk yard here. The 350GT-8 is basically a G35 sedan in Japan. It's got an 8-speed CVT tranny and paddle shifters. These shifters work on our 350z's after some wiring.
Old May 20, 2013 | 10:08 PM
  #82
silvertouringz
Originally Posted by Frostydc4
Looking good
Thanks.
Originally Posted by STL 350Z
I have a Fujitsubo Legalis exhaust and I have no rasp at all... not sure where you were getting yours from.
I had severe rasp after 4k rpm until i hit the rev limiter.
Originally Posted by jdmlove1
nice build man. love those wheels. change ur front headlights to 06+
Thanks, headlights coming soon.
S-techs is a nice springs and will give you a sexy look if you do "rear mounts cut" & good for your streets in Lebanon! i am running them too.
I already had the rear mounts cut when I was installing the nismo suspension You're right, better go with springs here than spend $2k+ on coilovers and then blow the struts after 5k because of terrible roads here.
there were rasp in the Fujitsubo coz u removed the resonator i think. i did the same mistake with the stock exhaust. removed the resonator and had rasp. till i change to Tanabi medallion.
I had some rasp before removing the resonator from 4k rpm onwards, however it was much worse when i removed the resonator.
Old May 20, 2013 | 10:09 PM
  #83
silvertouringz
Originally Posted by 350zsunshinefl
I have to second that as well, I have a Legalis as well and there is no rasp in low or high rpm range,
(I have an 07) Not sure if the HR engine makes a difference or not but I love the exhaust note,
I actually had a nismo s-tune before the fuji and I love the fuji sound the gurgle/burp is way more pronounced vs the nismo...
Not to mention the tips look awesome
back on topic;
love the car transformation
can you make a video with paddle shifters in action?
Thanks
Yes, will do a vid for sure as soon as I get my transgo in.
Old May 20, 2013 | 10:10 PM
  #84
silvertouringz
Originally Posted by Zatara
Can thos Z1 motorsports UHP hatch struts be used with the original brackets???
They already come with brackets, however they rust really quickly for some reason. I believe they do work with OEM brackets, however I would double check with Z1.
Tochigi_236
Sep 27, 2015 03:40 PM
