New member, with questions
Old Feb 17, 2013 | 06:15 PM
teh_pledge's Avatar
teh_pledge
Default New member, with questions
I recently purchased a 350z unexpectedly. I was searching for a car to buy (not 350z) and I stumbled upon this and fell in love with it! I've got a few questions because it is not perfect, needs a little love but I'm sure most of it is an easy fix. But first I'll start off with some pictures, I know everyone loves picture.
I'm looking to buy some stock wheels until I buy coilovers. Any opinions on which coilovers I should get for daily driving? Won't be tracked or anything like that. Looking to keep it under $1,000. I'm also buying OEM taillights tomorrow, I hate the ones that are on it now. Anyone know what they are?
Questions:
1. My speedometer doesn't work (the analog one). But the odometer works and the digital speedometer works as well. What could be the problem?
2. My passenger window doesn't work. I hear the motor turning on but it doesn't go up or down. Window regulator?
3. My seat belts don't retract, how would I fix that?
4. My clutch squeaks, do I just lube it up?
5. My e-brake barely works, I have to pull it up all the way to the top and it only catches a little bit, any way to adjust this?
Old Feb 17, 2013 | 06:44 PM
taryon's Avatar
taryon
Congrats on the Z, good call on the taillights!
Window motor regularly has problems and there are heeps of info regarding it on the forums.
Old Feb 17, 2013 | 06:52 PM
oldschool350z's Avatar
oldschool350z
Window motor. New one from online OEM is $170.. I know because im in the same boat
Old Feb 17, 2013 | 06:57 PM
teh_pledge's Avatar
teh_pledge
Yeah I don't like them one bit. Found some oem ones locally for $140.
Thanks guys. I'll be ordering that tonight!
Old Feb 17, 2013 | 07:00 PM
oldschool350z
cool! Make sure it's the revised part. I can't remember what it is offhand but there are two different ones.
Old Feb 17, 2013 | 07:05 PM
teh_pledge's Avatar
teh_pledge
How do I know which one to choose?
Old Feb 17, 2013 | 07:16 PM
Spike100's Avatar
Spike100
Questions:
RE> The needle is “stuck.” The repair may require replacing the gauge. I’ve never done that so I do not know the cost
RE> This is a common problem with the Z. Cleaning the window motor fixes it, but just for a short time. I replaced my window motors for a true fix. It’s interesting that you mention the passenger side because it is usually the driver side window that is the problem. Of course, the basis is how many times the motor is engaged, so it could bed the passenger side is the driver side was rarely used and the main use was the passenger window.
RE> That is a safety device failure and covered by Federal Law. Return the car to any Nissan dealership for a repair that does not cost you anything.
RE> No. Your pressure plate is slipping. You need to replace this, and probably the entire clutch assembly.
RE> I had the same problem. I had the dealership repair this. It was inexpensive so I assume it was an adjustment.
--Spike
Old Feb 17, 2013 | 07:23 PM
teh_pledge's Avatar
teh_pledge
Originally Posted by Spike100
--Spike
Thanks so much man!!! So just replacing the whole cluster would solve that problem? I'd rather find a used one that works than try and fix the needle. It's funny you mention that about the clutch because the previous owner told me it was replaced less than 1,500 miles ago lol.
Old Feb 17, 2013 | 07:46 PM
dcains's Avatar
dcains
If both seat belts don't retract, that's a pretty good indicator of an airbag inflation. Too much of a coincidence, otherwise.
j3tt2's Avatar
j3tt2
Looks good man! About those oem wheels your looking for. What kind of condition are those in? I might be willing to trade my oem wheels
Old Feb 17, 2013 | 07:59 PM
teh_pledge's Avatar
teh_pledge
I'll just take it to the dealership and see how it goes.
It would really have to be local unless you want to ship yours first since these are my only wheels and I drive my car everyday.
Old Feb 17, 2013 | 09:41 PM
winchman's Avatar
winchman
It looks like your parking brake needs adjustment.
Have the seats been replaced? I don't recall seeing leather seats with no cruise control. Replaced seats might be another indication of previous airbag deployment.
Old Feb 17, 2013 | 09:48 PM
Planetwister's Avatar
Planetwister
Those wheels look way sexy with that color blue!! Way nicer than stock. Anybody know what kind those are?
Old Feb 17, 2013 | 10:31 PM
Jennifer 2's Avatar
Jennifer 2
In regard to your window problem, I’m not sure Spike has correctly interpreted the information you supplied. The power window motors are indeed a weak point in a Z. The motor brushes tend to wear down and lose electrical contact inside the motor. At this point the motor stops running or at best runs intermittently. If you can clearly hear the motor running, then (as you suspected) it may have become disconnected from the regulator. Possibly due to incorrect assembly by a previous owner.
After many years duty, it’s not uncommon to hear a single squeak when letting up the clutch pedal. You can hear it more clearly without the engine running. Usually this is a lack of liberation between the clutch-arm (that runs between the slave cylinder and the throw-out bearing) and the spherical shaped stud it pivots over. The man who services my Z simply peeled back the rubber boot on the bell housing and applied a dab of anti-seize lubricant with a stiff brush to the pivot ball. There are some excellent write-ups here on how to do this.
Old Feb 17, 2013 | 10:55 PM
samsniss350z's Avatar
samsniss350z
To adjust your E-brake, remove the ashtray (just pull it up and it will pop out) you will see a hole on the back face, look in and you'll find a nut, get a long reach socket or socket with an extension bar and screw clockwise to adjust, make sure E-brake is off when you do this. Adjust until your E-brake no longer points skywards.
Old Feb 17, 2013 | 11:02 PM
samsniss350z
Forgot to mention that i'm in agreement regarding your rear lights they're the most hideous i've seen on a Zed, i've only ever seen one other Zed wearing them thus proving the point.
It looks like you need an aerial unless the previous owner fitted an electric one.
I'd keep the wheels, i reckon they really suit the colour of the car and look better than OEM's
Old Feb 18, 2013 | 04:52 AM
Jah70's Avatar
Jah70
So helpful. I had the same problem with mine. The car looks nice! glad your getting rid of those taillights. Those things look weird. Those wheels really compliment the car's color, I wouldn't get rid of them because they look way better than stock.
Old Feb 18, 2013 | 05:46 AM
Slyguy_38's Avatar
Slyguy_38
About the leather seats without cruise-control; I zoomed in on the pic of the seats and could clearly see the Power, Cancel and the RES-ACC/COAST-DECEL rocker switch on the right spoke of the steering wheel.
I'm not a fan of the wheels, but its because I prefer the stock ones. These look good though. I've seen worse.
Great information about adjusting the parking brake. As long ad the pads are good and all the hardware is working well, an adjustment may be all that's needed.
I have an '06 and the whole tail light is an awesome and much sought after thing. I actually like the tail light lenses on this car. I've seen many that are much worse and these are actually an improvement over the stock '03-'05 IMO..
Curious about the seat belts and their link to the airbags.
Old Feb 18, 2013 | 05:53 AM
teh_pledge's Avatar
teh_pledge
Thanks for all the help guys! The car does have cruise control so I don't think the seats have been replaced. I picked up OEM taillights and will be putting them on today most likely. As for the wheels, I do like them just not since the car is stock height. I think it looks weird at stock height with aftermarket wheels. They're WedsSport SA-70 for the guy who asked what they were.
I will be buying a new window motor or at least checking to see if mine isn't properly connected. And thanks for the clutch answer, I will try to lube it up before actually replacing it.
Old Feb 18, 2013 | 07:35 AM
zswickliffe's Avatar
zswickliffe
I'd be willing to sell you some OEM wheels (18x8 - wheels off the performance model "touring V1" http://www.nicoclub.com/archives/350...ion-guide.html). The previous owner gave them some curb rash but they're all fine structurally. PM me if interested
