Help. Looking at buying a 06 350z with 08 hr motor
Old Aug 12, 2013 | 09:31 PM
arrowman413's Avatar
arrowman413
Default Help. Looking at buying a 06 350z with 08 hr motor
Hi, I am looking into buying a 06 350z with 50k miles on the body. But there is only 35k on the 08 motor. Should I be worried about this purchase? Also, what should I be looking for when I go to look at this vehicle?
Old Aug 12, 2013 | 09:33 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Run away.
Old Aug 12, 2013 | 09:38 PM
pyshin's Avatar
pyshin
Originally Posted by MI 35th
Run away.
x2.
Please read through the following sub-forum before posting again:
https://my350z.com/forum/buying-leasing-396/
Old Aug 12, 2013 | 10:05 PM
Bmurray350z's Avatar
Bmurray350z
if its a really good price then just have it checked over by a nissan dealership or a trusted mechanic.
Old Aug 12, 2013 | 10:32 PM
KingBaby's Avatar
KingBaby
Hardest Setting
buy it
Old Aug 12, 2013 | 10:57 PM
terrasmak's Avatar
Interesting , post pics of the build.
Old Aug 13, 2013 | 12:25 AM
winchman's Avatar
winchman
It's hard to believe a person would do that unless the first engine was trashed, and that doesn't bode well for the rest of the car. Of course, it could have been done to resolve an oil consumption issue, but it still seems extreme.
Old Aug 13, 2013 | 06:24 AM
Landon_G03z's Avatar
Landon_G03z
According to everything I've read on the de to hr swap, it's way too expensive and not monetarily worth it. I thought it hasn't been done! I'd like to see pics as well
Old Aug 13, 2013 | 07:18 AM
travlee's Avatar
travlee
Master
with the HR's they have clutch issues.....
Old Aug 13, 2013 | 07:46 AM
stuartc323's Avatar
stuartc323
Pretty sure transmission is same, not the engine though, IIRC
Anyways OP run, find a clean stock car.
Old Aug 13, 2013 | 09:34 AM
travlee's Avatar
travlee
Master
the transmissions are WAY different, the HR have the internal slaves that are known for going out, the de has the external clutch fork.
Old Aug 13, 2013 | 09:42 AM
arrowman413
Hi, thanks for the fast responses. The guy claims the car got the new motor from a recall. I guess when i look at it today i will look at the paper work to make sure it was what he said.
Old Aug 13, 2013 | 09:44 AM
stuartc323's Avatar
stuartc323
For sure learned something new today
Old Aug 13, 2013 | 09:54 AM
NissanZguy's Avatar
NissanZguy
Sounds like a BS ploy to give incentive for the purchase.....run away.
Old Aug 13, 2013 | 10:01 AM
arrowman413
Ok, thanks for the fast responses everyone. I will still go look at the car, but i will definitely do more research into what he has done to it before i purchase. I will also definitely have a Nissan mechanic look into it.
Old Aug 13, 2013 | 10:05 AM
pyshin's Avatar
pyshin
To my knowledge (someone please correct me if I'm wrong) there was never a recall that required Nissan to swap a newer HR engine in place of a RevUp... They would have to replace the engine, engine crossmember, hood, ecu, wiring harness, etc. etc. RevUp's do have a oil consumption issue sometimes but that is easily remedied by proper maintenance...
Again. Run away.
Please just find a solid used 07-08 HR.
Old Aug 13, 2013 | 10:24 AM
travlee's Avatar
travlee
Master
if it was recalled there will be documentation on nissans part... ask to see it
Old Aug 13, 2013 | 12:18 PM
350zchad's Avatar
350zchad
this tool prob means the motor was put in in 08.. no way the dealer stuck the HR in a DE car
Old Aug 13, 2013 | 02:06 PM
radiocrash's Avatar
radiocrash
I personally would never buy a car with a swapped motor. Just my $.02
Old Aug 13, 2013 | 02:59 PM
l2iceman's Avatar
l2iceman
pop the hood and see if it has dual intakes...he may be lying or assuming it's an 08 engine since the oil consumption issue recall may have been address in 2008.
