Stereo install -- pics and all!! (Fixed links)
Guest
Posts: n/a
I got tired of having my car torn apart. I felt like I had violated her. I'm want to drive my car tomorrow and see how many squeaks and rattles I installed, so I put her back together.
I could NOT find any amp under or behind the glovebox. If somoene can find an amp behind the glovebox, I want to see pictures. Z461, are you sure your installers found an amp behind the glovebox? I think there is only the one amp under the styrofoam in the left rear deck between the spare tire and antenna.
My Bose hunt is over for awhile. Someone else can take over now.
Questions for Z461 to ask his installers:
1. Were there one or two amps? If two, exactly where is the one behind the glovebox?
2. What signals did they find on what wires (color codes)? Did they find all the signals they needed in the bundle going to the rear amp? I think you said they did, but I just wanted to confirm. Please confirm the signal levels also.
3. Did they remove, power-down, and/or disconnect the Bose amp entirely? I assume so. I want to make sure the head unit still works without the Bose amp connected to it. It appeared to work when I disconnected them, except for no sound from speakers, which is to be expected, unless you think some of the speakesr are powered by the head unit.
4. Which amp(s) drive each of the 7 speakers? Does the head unit drive the tweeters as mentioned?
I believe that there is only one amp in the back and that all 7 speakers may be powered out of it. I'm skeptical about the tweeters being powered by the head unit because when I disconnected the Bose amp, those tweeters didn't make a peep.
My best guess is that what Z461's installers did was to use the DVM visible in the photo to find the four line-level signals. Using the balance and fader control and a DVM, you should be able to identify the four wires you want out of the 20 in the bundle. Then they probably just ran those four line-levels into their aftermarket amp and ran new wires to all the speakers. I don't think the stock wires could handle the power of the aftermarket amp and speakers.
I would think that anyone thinking about putting in an aftermarket amp and replacing the Bose could follow this procedure. It would be nice if someone who's done it would just post the color codes of the four wires we want and confirm their existence and signal levels. They might be speaker-level outputs. If so, it appears that most 5-channel amps available now have both line and speaker level inputs.
It would also be nice if someone could get a peek at a technical service manual on the Bose system so we could come up with a way to defeat the auto-EQ/VOL function until we replace it. I would probably just live with it, myself. But the subwoofer would still sound like it was wrapped in a blanket and stuffed in the gas tank.
Originally posted by nizl
Man what a pitiful excuse for an "amp".
As far as Gcinfl's research and which speakers the amp powers, is everyone *positive* that the amp drives more than just the sub? Is it possible that the powered signal wires from the headunit could just be running up through that harness in some way, and not actually going through the amp? In most other car Bose systems I've seen, they almost always use the headunit to power at least some of the speakers.
GC, when you pulled the amp harness and all the speakers went dead did you pull the signal harness or just the power harness?
Hopefully this weekend I will be able to take the backend of the car apart to see what I can come up with, although I have company in this weekend so it might be abreviated. I am going to make sure to bring my multimeter and a small o-scope.
JUST A QUESTION:
Until either Nissan/Bose comes out w/ a fix or I get to a shop to swap out the amps (listen to me, I don't even have my car yet *S*)...can the leads at the back of the sub unit just be disconnected?
I know this isn't a fix, but it seems that it would at least get rid of the sound of the crappy sub when the system's auto EQ/volume does it's crappy thing.
Thanks
VG
Thanks
VG
Guest
Posts: n/a
Originally posted by ATL350Z
And what a wonderful place to put it too. Nothing like a hot amp under a big piece of styrofoam.
As far as the disconnect, I did both. The speakers went dead, but not the head unit, when I pulled either or both of the two connectors. Not surprising. I think one has the power and the other has ALL the speakers.
I would already have a new amp in there if I had thought the factory speaker wires were heavy enough. I don't want to do all the disassembly that is required to run new speaker wires to all the speakers (probably wouldn't have to do the tweeters).
The good thing about the styrofoam is that it will be easy to cut out around a larger amp. The way the amp is mounted is upside down with the heat sinks facing downward about 1" off the floor below it. There is a sheet metal bracket holding it upside down off the floor that screws down with 3 screws. The amp is screwed to the bracket with 4 screws.
With a scope I think you could pull the cover off the amp (looks like just 2 screws) and trace signals around the circuit board.
To get to the amp:
1. Pull out rear deck carpet, mat, fiberboard, spare.
2. Remove felt piece on left rear quarter-panel inside by pulling off the plastic piece that slips under the hatch door seal (pull up).
3. Pull off plastic piece on rear inside that contains the hatch area light.
4. Now the fun part is maneuvering the styrofoam out from under the strut tower brace left side base and up. You can't just slide it sideways, that's why steps 2-3 are required.
You're there. Happy signal hunting.
Take a look at the wire gauge to the speakers, if that's where they go, so we can calculate how much power they can handle. I'd really like to swap out the amp if it can be determined it can be done without replacing the wires. The other problem is the power to the amp. I don't think those wires are heavy enough either. Let me know what you think.
I'm thinking of just a little 5-channel amp to replace the Bose. It's hard to find one that's less than about 350W total (4x50, 1X150).
Morning,
I was trying to access the pic file from your subwoofer install. Of specific interest was the stock sub cover modifications. I have a Audiobahn 10" (some new model my son obtained for me) that has quite a bit of excursion. Try as I might, depth of this sub precluded me from fitting the enclosure low enough in car to enable full range of motion of sub. I've seen your install referenced twice, but neither link seemed to work. I also tried to get to "naturalclear" site but this was not possible, either.
Would you please provide a path I can use to review your sub install mods? Thanks in advance.
Sorry for bother.
TB
Sorry for bother.
TB
Workshop12
Mar 23, 2020 01:45 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
