Z1 Osiris Mail In Flash Service
Old Mar 18, 2014 | 09:06 PM
Jmfeld02's Avatar
Jmfeld02
Default Z1 Osiris Mail In Flash Service
Do any of you have experience with Z1's Osiris mail in flash service? You mail in your ecu and they upload tunes based on your specific modifications. It sounds similar to what Technosquare used to do, except this way you get the benefits of the Osiris software with the fancy map switching. I'm curious if they change parameters such as timing or if they just mess with fuel delivery. It certainly is a cheap alternative to dyno tuning at a price of $300. It seems to me to be a budget option for those who aren't looking to squeeze every last drop of power out of their car, but want to take better advantage of all their bolt-ons. I'm sure it would also solve the problem of running lean from mods. I was just curious if anyone on here has done this and what their assessment of it was.
Link to the service:
http://www.z1motorsports.com/350_g35...oducts_id=3294
Old Mar 19, 2014 | 05:30 AM
Jah70's Avatar
Jah70
Subbed. I'm also curious about this too.
Old Mar 19, 2014 | 06:01 AM
samsniss350z's Avatar
samsniss350z
Another curious Z owner here who'd be really interested in hearing about anyone who has used this service. Bring on the testimonials.
Old Mar 19, 2014 | 09:47 AM
fd3toe46's Avatar
fd3toe46
I did not do the mail-in service per se. I did buy a standard Osiris from a member on g35driver and he tuned my car from datalog. What happens is I installed the Osiris tune...did a couple of pulls from 20 or 40mph to 70 or 80mph (can't remember exactly) and then email him the datalog. He does what he does on his end and send me back the new map file...he's very easy to work and worked with me until we got the desired afr number...I was running fairly lean before this.
The difference being the mail-in would take forever and even the e-tunes from Osiris themselves takes awhile to get back. It has been over a year since I did this and my car runs around 13.5-13.9 still a little lean but I have saved up some money and will be doing a dyno tune as soon as I have the time.
Old Mar 19, 2014 | 10:01 AM
seymore4's Avatar
seymore4
Professional
If you mail in your ECU you're going to have a bunch of downtime where you can't drive your car.. and what happens if it gets lost in the mail or something? Also the tune is going to be very generic.. not based on your datalogs at all.
I know a protuner that does the same service but has loaner cables so you can reflash it yourself at home and then adjusts based on the datalogs.. Same as Osiris Standard but the budget version. Once you send the cable back and get the deposit refunded its the same price.
PM me if you're interested and I'll send his contact info over
Old Mar 20, 2014 | 04:20 AM
Jmfeld02's Avatar
Jmfeld02
Surely someone has used this service and could provide us with some feedback. At the least, maybe Z1 could comment and explain how this service works and how close it usually gets to a custom dyno tune.
Old Mar 20, 2014 | 06:08 AM
Z33Garage's Avatar
Z33Garage
Subbed for info!
Old Mar 20, 2014 | 07:44 AM
PerfZ's Avatar
PerfZ
Someone(s) obviously skipped over the part where Z1 says they will attempt to turn in 48 hours. and you can pretty much trust them to do as they promise - every single time. With that said, you are not going to get the same final effect that you would with a full dyno tune, but you will see some improvement. Just don't expect too much - you are not going to gain 50 HP or any such nonsense - from either method.
Old Mar 20, 2014 | 07:55 AM
BigBlue's Avatar
BigBlue
Can you make some Cipher logs, email to them and just have them email an E-tune and then use your Osiris to flash it onto your ecu yourself? You can flash a new tune in about one minute.
Old Mar 20, 2014 | 09:59 AM
seymore4's Avatar
seymore4
Professional
Only if you purchase the Osiris standard package for $500 that comes with the reflash cable. With the mail in option you just get the license flashed onto your ECU.. no cable
Old Mar 20, 2014 | 03:18 PM
BigBlue's Avatar
BigBlue
Thanks for clearing that up, I didn't realize. It will be interesting how that process works, may be the best way. Good luck with it.
Old Mar 20, 2014 | 03:50 PM
Jah70's Avatar
Jah70
I might get the standard osiris standard just because there are more options and I got other breather mods coming in the future.
Old Mar 20, 2014 | 04:23 PM
seymore4's Avatar
seymore4
Professional
Standard is a much better option; not only can you reflash updates as needed but you own the cable so you can reflash back to stock and sell it used if you ever need to.
Old Mar 20, 2014 | 04:55 PM
BigBlue's Avatar
BigBlue
You own the cable with the Tuner UpRev kit also, but you must create any tunes by yourself "if" you know what you are doing, otherwise you have a mechanic/UpRev tuner hooked up with the tuner kit software using your cable/license, creating your tune most likely while your car is on a dyno and adjusting the parameter #'s until he likes what he sees, etc. I have the standard kit myself. You use Cipher to record data logs that the tuner/E-tuner looks at, creates an E-tune and emails it to you so that you can hook up your lap top and using Osiris, flash it onto the ecu.
bneumann
Oct 7, 2015 12:16 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
hulkout
Tuning
Sep 18, 2015 05:42 AM
