Inputs please...template for 350 grille.
Old Sep 15, 2002 | 10:32 AM
Seattle_350Z's Avatar
Seattle_350Z
Default Inputs please...template for 350 grille.
This is the template I'm planning on sending off for a prototype grill. I will attached grill material which will be made out of steel and powder coated. I need all of your inputs. See pixs.
Old Sep 15, 2002 | 10:33 AM
Seattle_350Z
Default template.
pix
Old Sep 15, 2002 | 10:35 AM
Seattle_350Z
pix
perfectlyfrank's Avatar
perfectlyfrank
Charter Member #09
How will you get the tow hook in if you ever need to use it?
Old Sep 15, 2002 | 10:40 AM
Seattle_350Z
The grille will attach over the existing grille by plastic ties. I'm going to have a pair of scissor in the car handy....I talked to the company and they used plastic ties on most of their grille...which they claim works the best.
Old Sep 15, 2002 | 10:41 AM
Seattle_350Z
pix
Old Sep 15, 2002 | 11:35 AM
DIGItonium's Avatar
DIGItonium
I was thinking subwoofer speaker grille.
Old Sep 15, 2002 | 11:42 AM
Seattle_350Z
If you have a pix of alternative material it would help. I think this is the only material they use. I co-worker of mine has it on his S2000....it's awesome! Something like this pix. You can see it overlaying the original grille.
Old Sep 15, 2002 | 11:54 AM
Zoro's Avatar
Zoro
Default wow
I sure do like the way the front end of the s2000 looks with or without the grill.
Any way the grill on the s2000 appears to have some type of black channeling around it. You'll need that too or it's not gonna look very clean. It probably helps to keep it from curling up under air pressure as well. I don't know about plastic ties though, it seems they would stand out like a sore thumb.
Old Sep 15, 2002 | 12:50 PM
nissan350zparts's Avatar
nissan350zparts
I just installed a plastic screen behind my grill. Too many bugs met death on my radiator. I also noticed the area behind the grill is very air tight forcing most of the air through the radiator. There are a few leaks by the air intake where they seam to have put a peice of foam but still has leaks. Also 350z brocure and website show belt driven fan but it has 2 electric ones. I'm thinking of drilling holes on floor pan behind grill to let the water drain out, the pan behind the radiator has hole.
Old Sep 15, 2002 | 12:52 PM
roberto350z's Avatar
roberto350z
you might need a HUGE wing to go with that grill
Old Sep 15, 2002 | 01:12 PM
wadd3456's Avatar
wadd3456
Default Hmm
Gutter mesh is the one thing ive used in the past. Also the stucco grid stuff works GREAT and wont rust.
I have a garage full of the stuff.
Scott
Old Sep 15, 2002 | 01:49 PM
BILZ Z's Avatar
BILZ Z
Definetly the Black. I don't know about the plastic ties. Thieves carry scissors also.
Old Sep 15, 2002 | 03:05 PM
z350z's Avatar
z350z
Charter Member #13
I think this will look great on the 350Z. I think I might get the silver (when it's available) which should look great with Daytona Blue.
Old Sep 15, 2002 | 06:57 PM
Seattle_350Z
Finished template. Fixed the corners.
Old Sep 15, 2002 | 06:59 PM
Seattle_350Z
Corner shot.
Old Sep 15, 2002 | 07:07 PM
Seattle_350Z
Zoro,
The grill will come with the black channel (u-shape). It will look professional. I'm just a regular Joe working with the manufacturer that's all...since they don't have the Z.
Here's the process:
1. Once I send off the template.
2. They will use this and map it using CAD for the real template.
3. Send it out for laser cutting.
4. Send it to me for fitting.
5. Repeat steps 1-4...if it doesn't fit right.
6. Step 1-4 should take about a month.
7. Then it will be available to the public for under $100.
8. Wish me luck in getting right the first time!
9. NO I do not get pay for doing this.
10. Just wanted this grill so BAD.
Old Sep 15, 2002 | 07:14 PM
raceboy's Avatar
raceboy
A grill over another grill=RICE. End of story.
Old Sep 15, 2002 | 07:21 PM
Seattle_350Z
Well, I don't think that S2000 looks RICE. I seen it in person for the Grill material and on an S2000, it looks very nice. This is don't professional not Home Made.....I'm just working on the template for them. No I'm not going to put sticker or a huge wing on my car....c'mon I spend 40K on this thing.....whatever goes on it will be nice. Oh I would mind getting the NISMO wing and body kit when it's avail (I'm planning on getting only NISMO stuff when it avail.
Old Sep 15, 2002 | 08:23 PM
Boomer's Avatar
Boomer
Default Front grill
I have to say, I don't particularly like it. I think the stock grill looks great, but I've only had my car a week. Maybe after a few months, It might appeal to me, but not now.
Boomer--you asked.
