Stripped Nut on lower control arm help!
Old May 7, 2014 | 08:10 AM
Ianvo23's Avatar
Ianvo23
Originally Posted by trixal
I just stripped this same bolt this weekend. I cut it off with a dremel and replaced it. Took about 5min to cut and a trip to ace hardware.
What size bolt was it?
Old May 8, 2014 | 05:31 AM
clubhopper's Avatar
clubhopper
I've used a carbide tipped nut splitter on a similar spot. Also an impacting the bolt side works good as well. I've also used a dremel tool to cut off the nut as well. What worked the best was the nut splitter...if you can't impact it off the other side.
