Drone - Fixed
Drone - Fixed
While driving at highway speeds this weekend, my 350Z developed a noise that sounded very similar to an exhaust drone.
At 3000 rpm, it sounded like: "Hmmmmmmmmmmmm"
After jacking it up, crawling underneath, and inspecting everything . . . . I discovered that a rubber boot that was designed to protect the manual shifter linkage had come loose. It was resting and rubbing on the drive shaft.
Since it was ruined by all the rubbing, I discarded it.
Noise gone, problem solved.
Now if I can only find that rattle in the trunk area . . . .
350Z/370Z Tech Moderator
General & Tech Moderator
Zoom zoom Mic, keep up jk
Oh, thought you might have gotten into the wrong car that turned out to be a Mazda.
Hint: You have to be over 40 to get that one. Hint:
Mazda RX-3 Commercial - YouTube
Sorry, I'll go to my corner now.
on
Now if I can only find that rattle in the trunk area . . . .[/QUOTE]
I agree! I have a rattle/squeak in the trunk area as well. I removed the jack thinking that might have been it, but no luck. Maybe this is a common problem?
A VERY common trunk area rattle in these cars (as well as first and second gen G35's) are the rear shock mounts. I was pulling my hair out because of that damn squeaking/rattling/clanking.
If you've played around with the jack, the spare, and the plastic hatch trim panel and still haven't been able to find the noise, it is almost assuredly those shock mounts. They're $20 a side and takes around a half an hour to do, and that's with a beer break! No more noise! Do it!
General & DIY Moderator
No such thing as a dust free roadway, Sunday driving or not. Any kind of grit that works its way down into the linkage is not easy to clean out and will, over time, degrade the smooth operation of your shift mechanism. Besides, this is a Z, not some econo beater you can cheap out on. You're telling me it's not worth doing this simple repair on?
