Is this injector fine?
Old Apr 8, 2015 | 10:05 AM
Artem_kiev's Avatar
Artem_kiev
Default Is this injector fine?
Hello everyone!
I've just received a set of used OEM injectors and one of them has this kind of damage.
I've flow tested them at the shop and they said injectors are ok, but when I brought them home I've seen this kind of damage. And I've checked ebay photos - it was there even before flow test.
Just wanted to know if this kind of damage will affect spray pattern.
Old Apr 8, 2015 | 04:53 PM
Mint Racer's Avatar
Mint Racer
as long as its not cracked you should be alright. the nozzle looks to be undamaged, aside from the dent in the casing. if another can be had easily, then get another, for piece of mind. but nothing wrong with installing it to see if it works, if it causes a misfire on that cyl then replace it.
Old Apr 8, 2015 | 06:12 PM
venture210's Avatar
venture210
as long as the o ring still seals right
+1 to mint racer. Misfire = change it out
Old Apr 8, 2015 | 11:55 PM
Artem_kiev's Avatar
Artem_kiev
Thanks a lot for answers.
That's what I wanted to hear)
