03 350z will not turn over at random
Old Jun 25, 2015 | 05:08 PM
Joelbernard's Avatar
Joelbernard
Default 03 350z will not turn over at random
Please help,
Ive read apparently all the threads on this none suit my issue, i have a 2003 nissan 350z that works great when it starts but some days it decides it doesnt want to turn over at all. Sometimes for a minute sometimes for an hour, then all the sudden it starts. The car starts up right away as soon as it starts cranking but when this issue happens i turn the key and nothing at all happens everything goes blank.
I checked the battery and it shows that its good, 12.8v when off and 15-16v when the car is running. All the power works in the car before this happens, as well sometimes it will start to click/crank and stop halfway and cut back to nothing. Almost like it tryed to work but got cut short almost instantly, this is very annoying since lately its EVERY time i go to start it it happens. I desperately need help i am in no financial condition for a stealership bill at the moment, some helpfull information: the battery was replaced last year, clarion navigation head unit and my one and only key has a chip out of the plastic near the base.
Appreciate the help in advance
Old Jun 25, 2015 | 06:18 PM
travlee's Avatar
travlee
Master
how do the terminals of the battery connections look?
it could also be the camshaft sensors, when they go bad they can cause some of the issues you are describing
Old Jun 25, 2015 | 07:47 PM
zenki_z33's Avatar
zenki_z33
I've had this issue. Replaced both camshaft position sensors, haven't had a problem since. Good luck man
Old Jun 26, 2015 | 06:38 AM
Joelbernard
Default Thanks!
Ill look into the camshaft position sensor, my battery terminals are fine i used a wire brush (battery specific) for the tterminals they are clean and making solid contact. If the sensors work thanks a million this is such a headache !
Old Jun 26, 2015 | 06:40 AM
travlee's Avatar
travlee
Master
replace both, they are cheap enough
Old Jun 26, 2015 | 08:22 AM
Joelbernard
I am gonna get both they want 300$ for both is that normal?
Old Jun 26, 2015 | 08:24 AM
travlee's Avatar
travlee
Master
if you get them from nissan, prob. most stand alone auto stores have them for about $40
Old Jun 26, 2015 | 08:49 AM
Sleepiedaze's Avatar
Sleepiedaze
when you say it doesn't turn over do you mean it cranks and never fires up. or you turn the key and nothing happens. could be your starter.
Old Jun 26, 2015 | 09:27 AM
Joelbernard
It doesnt crank just nothing happens, but sometimes itl start right up. Theres no clicking it just goes blank
Old Jun 26, 2015 | 10:48 AM
Moe747's Avatar
Moe747
Definitely the camshaft position sensor, I had the same exact issue. Your sensor can be loose so check that it is or not before you buy one. The connector is on the drivers side behind the engine, near the firewall.
Old Jun 26, 2015 | 10:52 AM
travlee's Avatar
travlee
Master
there are 2 of them, should be about the same spot on other side
http://www.courtesyparts.com/350z-pa...5_743_745.html
Old Jun 26, 2015 | 10:57 AM
dcains's Avatar
dcains
Could also be the safety switch on the clutch pedal is bad (disregard if you have the 5AT). Easy to bypass and check. If it was the cam sensors, wouldn't there ba fault code?
Old Jun 26, 2015 | 11:03 AM
travlee's Avatar
travlee
Master
not always
Old Jun 26, 2015 | 11:36 AM
Joelbernard
Wel heres an update, its still hapenning really bad. But i stuck my finger in the clutch switch underneath the pedal with the car in neutral and turned the key and it started up. Maybe its not engaging all the way? Its only worked once so ill test this theory a few more times to see if it works consistantly. If not im gonna resort to the "CPS". Tryinf to narrow this down, not really up to pay 300$ for sensors unless i know its them!
Old Jun 26, 2015 | 11:48 AM
travlee's Avatar
travlee
Master
https://my350z.com/forum/engine-driv...nd-adjust.html
Old Jun 26, 2015 | 12:05 PM
Joelbernard
You know what Im thinking thats it. Thanks for the link, im gonna take it off clean it and see if it works when im done its 2/2 on startups pushing the switch in with my finger atm
Old Jun 26, 2015 | 05:17 PM
dcains's Avatar
dcains
You're welcome.
leonchus
Sep 29, 2015 07:04 AM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
AbyteZero
Sep 22, 2015 09:17 AM
_koubie_
Sep 20, 2015 06:34 PM
RyansZ33
Sep 15, 2015 05:54 AM
