03 enthusiast lower ride than 04 touring?
Old Nov 25, 2015 | 05:04 AM
Bcampbel24's Avatar
Bcampbel24
Default 03 enthusiast lower ride than 04 touring?
So I drive a 2003 350z enthusiast with 160,000 miles and my dad recently bought a 2004 350z touring with 90,000 miles and when you drive them the 04 rides significantly higher... Both are stock ride height with stock suspension. Was the suspension different from 03 to 04? Or is the touring suspension different from enthusiast? His does ride significantly smoother than mine. I was just curious if they had different ride heights from the factory. I couldn't find an answer anywhere.
And here's a pic of the cars sorry it's not too great
Old Nov 25, 2015 | 05:24 AM
matik's Avatar
matik
70k more miles, I would say the shocks and springs aren't holding their own. Probably need replacing soon
Old Nov 25, 2015 | 06:36 AM
bith8791's Avatar
bith8791
What he said.
The Enthusiast has 17" wheels versus the 18" wheels on the Touring, not sure if that makes a big difference.
Old Nov 25, 2015 | 07:00 AM
Bcampbel24's Avatar
Bcampbel24
I'm pretty sure they're the original shocks... That would explain a lot. But do springs go bad? That's what changes the height...
Old Nov 25, 2015 | 07:12 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
They will sag a bit with age... **** some will even bust in half. Ford tourus and saab springs break all the time.
Old Nov 25, 2015 | 09:34 AM
Joe clan's Avatar
Joe clan
1. The spring age with some sag. not much.
2. Rim size will effect how high it sits.
3. Tire size will effect how high it sits.
4. Someone put lower springs or cut the factory one. Many people that don't want to buy springs will cut them to lower the car. So it will look like factory springs.
Old Nov 25, 2015 | 09:59 AM
dcains's Avatar
dcains
Which cars got the "revised" springs/shocks? Wasn't it the 2004.5?
Old Nov 25, 2015 | 10:12 AM
mr. sparco's Avatar
mr. sparco
Correct revised spring rates and bumpstop design in 04.5 but who knows what both those zs have been through.
Old Nov 25, 2015 | 10:34 AM
Bcampbel24's Avatar
Bcampbel24
Will driving on worn out springs and shocks make any difference besides bad ride quality and obviously it sits lower too
Old Nov 25, 2015 | 12:31 PM
mr. sparco's Avatar
mr. sparco
Handling and tire wear are affected.
Old Dec 2, 2015 | 05:14 PM
Frank_White's Avatar
Frank_White
i read a while ago that the 03 sit a little bit lower then the later models
MaxMiss
Nov 16, 2015 06:32 PM
CWDings
Nov 2, 2015 05:26 AM
