Need help with bcm replacement
Old Mar 26, 2016 | 08:14 AM
ssmokeyy's Avatar
ssmokeyy
Default Need help with bcm replacement
So my bcm has been damaged and need to replace it. I found one with the same plugs from the same year but the part number is off by the last digit.
Today I just seen that the bcm is coming out of a roadster and I have a coupe.
Has any one tried a roadster bcm in a coupe and does it work?
If this works do I need more than a locksmith to program the keys?
Old Mar 26, 2016 | 08:37 AM
HRMoneyPit's Avatar
HRMoneyPit
You will need somebody to change something. I got one from a auto same year but the part number was the same. But I couldn't start the car and didn't feel like paying someone so I just put the stock back
Old Mar 27, 2016 | 04:58 AM
ssmokeyy's Avatar
ssmokeyy
The bcm is from a 6 speed model so that part is the same as mine. What would need to be changed?k
Old Mar 27, 2016 | 11:51 AM
HRMoneyPit's Avatar
HRMoneyPit
I think it needs to be programmed to the car
Old Mar 28, 2016 | 12:43 PM
Spoolin'Fool's Avatar
Spoolin'Fool
What are your part numbers? i can see if they superseded to each other
Old Mar 28, 2016 | 05:41 PM
RWDBajan's Avatar
RWDBajan
http://g35driver.com/forums/engine-d...cment-bcm.html
Roubaix46
Apr 2, 2020 11:02 AM
Pete5150
Mar 24, 2016 08:20 PM
NissanZcrazy
Tuning
Mar 21, 2016 08:30 AM
Arrtus
Mar 21, 2016 02:22 AM
