350z hr vibration
Old 05-17-2016, 05:25 AM
dp350zhr
dp350zhr's Avatar
Default 350z hr vibration
Hi guys, my manual 2008 hr started with an horrible vibration about a week ago, we already checked the engine mounts and they are ok, same as the obd2 scan tells that the engine is fine. The car vibrates even when stoped, or in gears, and it gets stronger with the RPMs. They shift **** is where the vibration gets worst, its like holding a ****ing ***** all the time. What do you think the cause will be?
Old 05-17-2016, 05:30 AM
dp350zhr
dp350zhr's Avatar
Old 05-17-2016, 06:03 AM
turboed350z
turboed350z's Avatar
Its probably vibrating because you posted duplicate threads all over the forum
Old 05-17-2016, 07:14 AM
travlee
Master
travlee's Avatar
Received 9,059 Likes on 6,523 Posts
good times
Old 05-17-2016, 07:49 AM
BurgerBob
BurgerBob's Avatar
Trans mounts?
Old 05-17-2016, 07:50 AM
CNunes_95
CNunes_95's Avatar
Check your transmission mount and suspension bushings. If they're no good, go with polyurethane mounts and bushings
Old 05-17-2016, 07:54 AM
dp350zhr
dp350zhr's Avatar
I also checked that, trans mount seems to be ok, someone told me it could be the flywheel, what do you think?
Old 05-17-2016, 09:28 AM
SQuaLZ
SQuaLZ's Avatar
Can you elaborate more? Is your car misfiring?
If your car is running fine and it's doing it when stopped, my money goes on the engine or tranny mounts, even though you said they are fine
Old 05-17-2016, 09:45 AM
travlee
Master
travlee's Avatar
i think you just stick with one post instead two that are exactly the same
Old 05-17-2016, 10:06 AM
dp350zhr
dp350zhr's Avatar
The car is running fine, i changed the engine mounts and the tranny looks good, the vibration intensifies as the RPMs increase. I also checked for a misfire but the scan revealed nothing bad.
Old 05-17-2016, 10:52 AM
CK_32
CK_32's Avatar
Only thing I could assume is the trans mounts if you already checked the engine mounts.
My 03 GT did this when my motor and trans mounts were aged. But some stick play is normal. Or else it would shake your hand/tranny to death. Especially if you rest on the shifter.
How did you check the mounts tho? Cause Ive seen some people try and shake the engine and because they couldnt get it to move say nope they are good lol
Photos would help. And it could be the flywheel.. Did you install an after market? Maybe a video?
Old 05-17-2016, 11:10 AM
CK_32
CK_32's Avatar
Originally Posted by travlee
good times
Hey, I think I've seen you here before... I think I've been here before..
Must be dejavoo
Old 05-17-2016, 11:13 AM
travlee
Master
travlee's Avatar
i know right
Old 05-17-2016, 11:26 AM
SQuaLZ
SQuaLZ's Avatar
Talk about deja vu
Old 05-17-2016, 11:29 AM
travlee
Master
travlee's Avatar
There is a fifth dimension beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone
Old 05-18-2016, 05:11 AM
SQuaLZ
SQuaLZ's Avatar
I just almost choked on my breakfast as I was reading that at work lol
Old 05-18-2016, 07:04 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,261 Likes on 2,319 Posts
I second that.
Trav.... Trav..... so captured the essence.
Old 06-15-2016, 12:12 PM
Grassyknolls
Grassyknolls's Avatar
I am having a vibration issue as well. 2007 base with 92k miles. I am changing the plugs this weekend so hopefully it's not a misfire. But I have issues when I'm at 3000 rpm and decelerating by engine braking, the car sounds like it's lost a cylinder, but doesn't always do it. It almost sounds like a formula 1 car when it engine breaks, like a stutter. I have no check engine lights that come on. It does idle low sometimes then idles normal, and has the long start issue. My question is, should I replace the cam/crank senors? Anyone else have this problem? I haven't checked the mounts and all that yet but I had an inspection done a few thousand miles ago and they said everything was good.
Old 06-15-2016, 04:31 PM
Frostydc4
Frostydc4's Avatar
lol @ some of the posters ITT
But seriously a little vibration is normal for the MT cars (obviously the AT cars have the vibrations dampened out).
Just curious, is the vq35hr even fire or odd fire?
Old 01-21-2019, 06:37 PM
1badfairlady
1badfairlady's Avatar
did you ever figure out what the cause was?
Quick Reply: 350z hr vibration
