Sponsored by:
Sponsored by:
fairlady changes
Old 04-17-2017, 05:25 AM
Acidizer
Acidizer's Avatar
Default fairlady changes
was thinking of getting a 350z.
this one is listed as a fairlady. the reg plate is square and the brakes are not brembo.
so I have two question - can the front reg plate be changed to a long one? I can see the rear reg plate is built into the bumped so therefore can't be changed. not sure about the front...
also - how easy would it be be add bremo's? is that a very expensive or complicated proposition?
thank you!
Old 04-17-2017, 06:19 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
thank you!
Straightforward bolt on swap:
https://www.google.com/search?q=brem...utf-8&oe=utf-8
Old 04-17-2017, 07:03 AM
CK_32
CK_32's Avatar
Yes, and easy.
Brembos assuming you mean OEM calipers are a bolt on replacement.
But honestly unless your tracking the car I'd skip it. When looking to buy mine I saw a lot of data from hard core guys saying it's hardly a difference in preformance. Some guys side by side tested this.
The only thing you gain is unsprung gun weight. Which again if your not tracking it hard you probably won't even notice. But hey your money, wouldnt be a bad mod if you do it anyways.
Mine just happened to come with them so
The following 2 users liked this post by CK_32:
ARRRT (04-17-2017), Atreyu'z 350 (04-18-2017)
Old 04-17-2017, 07:57 AM
Acidizer
Acidizer's Avatar
i think they would improve the looks of the car i had in mind a lot in particular. i had the same brakes on my old car and they were great.
what would the best way of doing this? never upgraded or modded a car before. i don't know what needs changed. can i keep the discs that are already on there?
i presume this would cost a fortune for new all around brembo's? and where to even buy?
i seen some second hand on ebay - looked pretty rough and weren't cheap.
Old 04-17-2017, 09:50 AM
MicVelo's Avatar
Brembo is a great set-up due to the ability to take and expel heat from high performance use, e.g. track use. But doing it for looks is a joke and huge waste of money.
If you think eBay is too expensive, you'd better just skip it because...
No, you can't keep anything that's on the car now. You'll need calipers, rotors at minimum and if you're doing it smart, you'll budget in all new bearings (since its pretty much all apart), brake lines, pads, and of course fluid (along with the Motive bleeder to do it properly.)
Old 04-17-2017, 12:01 PM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
Crushed dreamer thread
