Is there anyway to manually adjust the driver side seat
Old Aug 5, 2017 | 12:18 PM
CausticxHollow's Avatar
CausticxHollow
Default Is there anyway to manually adjust the driver side seat
My switch does not tilt forward. One of my boys tilted it all the way back and it doesn't tilt forward now. It still slides back and forth but tilting forward no longer works
Old Aug 5, 2017 | 12:29 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Sorry, the electric seat motors are not manually adjustable. You could try to buy some manual seats from a salvage Z.
Old Aug 8, 2017 | 05:16 PM
StevanGrcic's Avatar
StevanGrcic
I have the same problem in my Z. Seat will not tilt using the switch but the motor is not broken. I verified the switch by hooking it up to the passager side seat. Switch worked without a problem.
My fix:
Ran two wires directly to the motor and connected them to a 18v battery to adjust the tilt. Switching the polarity changes tilt direction. Now I just keep a cordless drill battery under the seat in case I need to adjust the tilt.
Old Aug 9, 2017 | 04:59 AM
icer5160's Avatar
icer5160
You can use a "Power Probe" to activate just the tilt motor. But I would recommend checking the switch module. If the power seat switches/buttons are located in an area near the window where water can hit it, there's a chance some moisture got in there and started causing corrosion. I had this happen with the power mirror switch on my 99 Toyota 4runner. I was able to repair the switch by simply taking it apart and cleaning up all the copper contacts with some emery cloth. Followed up with some silicone paste (dielectric grease) to prevent further corrosion and add needed lubrication for the plastic bits. I used a Power Probe III to verify all the wiring circuits & fuse were good along with the mirror motors, pinpointing the root cause to the switch module.
Btw, the dealer wanted over $200.00 for a replacement switch.
-Icer
Old Aug 9, 2017 | 09:22 AM
zakmartin's Avatar
zakmartin
I know it's a common sense thing, but just be careful that you don't accidentally apply voltage to the seat's airbag module (if so equipped.)
Old Aug 10, 2017 | 12:55 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
If you completely rip apart the guts of the seats you can move the little square tabby and adjust manually... I did it with a power drill on a taken apart seat...
Special note... This will not be a simple or fast procedure and you will probably never be able to properly fix your seats.
