PCV open breather
Old Nov 5, 2017 | 03:52 PM
albaugh81's Avatar
albaugh81
Default PCV open breather
Trying out the EPS Tuning Breather kit. Comes with two small filters, two hose clamps, two end caps, one screw in adapter passenger side.
I had a oil catch can back in the day on the passenger side pcv then connected to upper plenum & caught oil. Now trying something else out.
Attached Thumbnails PCV open breather-20171105_153234.jpg   PCV open breather-20171105_153301.jpg   PCV open breather-20171105_153321.jpg   PCV open breather-20171105_154055.jpg
Old Nov 5, 2017 | 05:58 PM
CK_32's Avatar
CK_32
And this does... what?
Old Nov 5, 2017 | 07:20 PM
albaugh81's Avatar
albaugh81
Instead of oil vapors going into my plenum & diluting fuel mixture i'm keeping my ports/valves clean by not having the PCV hooked up. Same thing is being done with a catch can also.
Old Nov 6, 2017 | 07:24 AM
CK_32's Avatar
CK_32
Ok that's what I thought. Just wanted to see if I was a dumb and missed the point of it or if it was mostly for oil in the plenum.
Old Nov 6, 2017 | 09:11 AM
Atreyu'z 350's Avatar
Atreyu'z 350
They're on my ''to-do'' list too..
Old Nov 6, 2017 | 09:19 AM
travlee's Avatar
travlee
Master
I found his to do list
the last two will have people like WTF?!?!
Old Nov 6, 2017 | 09:47 AM
deeliciousqueen's Avatar
deeliciousqueen
I have the same except that driver and passenger valve ports are directly connected to a breather catch can.
Keeps my mrev2 clean and throttle body.
Old Nov 6, 2017 | 09:59 AM
Atreyu'z 350
lmao... Yeah, I'll get right on that... Who needs a luck dragon when you have a Z...06.
Old May 14, 2018 | 12:19 PM
Kevin Skene's Avatar
Kevin Skene
What's worse, starting a new thread without searching or searching and resurrecting a dead thread?
Guys. I'm installing my catch can and would like some...opinions...my DE is NA.
Non-vented catch can -> have inlets for both valve cover sides and one outlet to the intake tube or plenum (holds the vacuum)
OR
Vented catch can -> inlets for both valve cover sides and vent to the ozone. (will too much crankcase pressure build with the long lines and lack of vacuum?
