Oil Cooler relocation help?!
Old Dec 4, 2017 | 06:32 AM
whippit's Avatar
whippit
Default Oil Cooler relocation help?!
I just tried to have the body shop install my new Astek N3R bumper, and they're putting it back together stock right now because there's an aftermarket oil cooler interfering with where the new bumper bottom support should slide. Anyone know how I should get this back to stock, where I could relocate this Mickey Mouse-ness, etc... In other words, what should I do here, easiest?? Thanks very much for all suggestions.
Old Dec 4, 2017 | 07:35 AM
iideadeyeii's Avatar
iideadeyeii
Pretty sure that's the stock power steering cooler. Look up instructions from the TN turbo kit to relocate to wheel well. Doesn't take any more parts to make it work.
Old Dec 4, 2017 | 08:20 AM
JMII's Avatar
JMII
Its not the stock cooler, as the stock one is much smaller (about 1/4 the size). This explains why its blocking the desired mounting locations. The zip tie mounting system is the aftermarket give away.
Old Dec 4, 2017 | 08:34 AM
Blurvision's Avatar
Blurvision
Easiest would be find OEM parts for the power steering cooler and remove that.
Old Dec 4, 2017 | 01:44 PM
CK_32's Avatar
CK_32
Yea that looks like an aftermarket PS cooler not a oil cooler.
Just look on eBay. That's where I get most of my OEM stuff at. Just make sure it's legit OEM and not a replica playing off as OEM.
Old Dec 4, 2017 | 02:24 PM
whippit's Avatar
whippit
Thanks to every one of the repliers, due to your help I just ordered a PS cooler off Ebay with the brackets that look like they'll line up with the 2 slots in the new bumper (apparently there's 2 types of brackets, I think one's strictly for 06s that are U-shaped, either that or those are for automatics...idk, but I got the other less bent version) But it came with all the lines right to the pump.
Sincerely, thanks.
Old Dec 5, 2017 | 08:40 AM
JMII's Avatar
JMII
I've boiled my steering fluid on track days so I was looking to upgrade. During my research I learned that this aftermarket unit (Derale 13200) is basically the same as the NISMO unit (49790-RSZ30US) but at much lower price. The difference between the stock and NISMO choices is only the length. The height stays the same and thus it shouldn't interfere with any bumper mounts.
Old Dec 11, 2017 | 06:12 AM
whippit's Avatar
whippit
Originally Posted by JMII
I've boiled my steering fluid on track days so I was looking to upgrade. During my research I learned that this aftermarket unit (Derale 13200)[/URL] .
JMII Thanks for the link, although I had ordered a stock 03 cooler, I ordered and just got in the unit you mentioned due to it's affordability and mounting zip rods that can be put anywhere I want on the engine rad, and it offers better cooling as you stated than stock.
I'll be selling my used stock 03 cooler with lines I just bought for $35, someone here can have it for $30 shipped to Cont US Priority.
