Tons of smoke
Old Jan 3, 2018 | 10:21 AM
KingInPrime's Avatar
KingInPrime
Default Tons of smoke
Hello,
I’m a new owner of a 2004 350z Touring model with 120k miles, there is tons of smoke coming from my exhaust, especially when I accelerate the car.
Old Jan 3, 2018 | 10:23 AM
KingInPrime
Old Jan 3, 2018 | 10:35 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
If its 0 outside it's normal, if its 70 outside its probably not normal. Whats your oil look like? If its watery its probably your head gasket. If it's normal you could be burning oil... Do you still have catalytic converters?
Old Jan 3, 2018 | 10:38 AM
KingInPrime
Yes, it does have a smell to it, could it be it’s burning oil? The oil meter is low and it goes up then drop when I accelerate
Old Jan 3, 2018 | 10:43 AM
travlee's Avatar
travlee
Master
someone under your car like
Old Jan 3, 2018 | 11:06 AM
KingInPrime
Left that meme in 2017 👎
Old Jan 3, 2018 | 11:15 AM
travlee's Avatar
travlee
Master
no care... sounds like you need to dig into the car, or pay someone to.
Old Jan 3, 2018 | 11:37 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Do a compression/leak down test to see what your numbers are. It looks like coolant burn smoke, but it could also be burning oil. Hard to tell because I can't smell it.. Check your coolant and oil levels(with the engine cold) and top them off if needed. Drive around a little bit to achieve operating temperature(if able to), then re-check both coolant and oil levels(after allowed to cool completely) to check for variances.
Old Jan 3, 2018 | 12:30 PM
thatsilverhr's Avatar
thatsilverhr
Originally Posted by KingInPrime
Hello,
the oil pressure is supposed to rise when accelerating because the engine is under more load and supposed to drop when off the gas
Old Jan 3, 2018 | 01:43 PM
rancor's Avatar
rancor
The oil pump is driven off the crankshaft and oil pressure is completely dependent on engine rpm and oil temperature. Oil pressure is not related to engine load in any way.
Old Jan 3, 2018 | 02:23 PM
liven Z life's Avatar
liven Z life
Your the new owner... why would you buy it doing that without having it looked at... or did it start after the fact?
Old Jan 3, 2018 | 03:51 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Start with Basic Auto Shop 101 Troubleshooting:
Blue smoke, burning smell = oil
White smoke, sweet smell = coolant (which, as Eyegor pointed out, this looks a lot like.)
White smoke, burning herb smell = SnoopDawg and Tommy Chong are in da house! (Or all the newly legalized "herbists" in CA are partying.) Sorry, couldn't resist .....
Go from there to diagnose/delve into the sub-systems affecting either.
While doing that, you should also pull the DTCs - if any - to rule out or point you to obvious issues.
Old Jan 3, 2018 | 03:58 PM
Atreyu'z 350
Milky oil and funky antifreeze is no bueno.
Old Jan 3, 2018 | 04:21 PM
KingInPrime
Looks white in person, (as a guess) (taking a wild guess without the diagnosis) what can be the fix for this issue?
Old Jan 3, 2018 | 04:24 PM
KingInPrime
Can the oxygen sensor relate to this issue?
Old Jan 3, 2018 | 04:49 PM
KingInPrime
Did some researching on the internet.
the car doesn’t over heat in 15-20mins, is it possible that it isn’t the head gasket?
Old Jan 3, 2018 | 05:32 PM
KingInPrime
P0051 HO2S Heater Control Circuit Low (Bank 2, Sensor 1
Old Jan 3, 2018 | 05:41 PM
CK_32's Avatar
CK_32
If you want to know if you blew your head gasket.
Drain the oil. If it looks like coffee or has 2 colors and clearly separation it means coolant is in your oil aka blown head gasket.
Check your intake manifold to see how much oil is in your manifold. You could just be burning oil really badly through the intake/cylinders.
Also like before did you buy it doing this? If you did I really hope you got it for cheap.
Old Jan 3, 2018 | 05:42 PM
dboyzalter's Avatar
dboyzalter
Did you look at your oil yet? What does that look like?
Old Jan 3, 2018 | 06:16 PM
KingInPrime
Default 350z
Yes I got it cheap 2.5k I’m freaking out, I checked the oil and it’s low I put oil in it the other day and drove it a few times
