350z '06 Headers.
Old Feb 6, 2018 | 03:38 AM
gotama's Avatar
gotama
Default 350z '06 Headers.
Yo guys,
I am thinking of replacing the headers of my '06 Z Uk model coz they I think they are in bad condition, I'm hearing some noises coming from there, they might be the heat shields tho.. but any ways I might as well replace with stainless steel performance headers.
I was wondering if anyone has the procedure of replacing the headers because my mechanic is talking about dismantling suspension and what not just to get to the headers and I thought I should ask for some information before I spend loads of labour to change the headers.
Anyone got a step by step easy to understand procedure so I can have an idea of the install time and forward it to mechanic
Appreciate any information anyone can provide
Cheers all, peace out
Old Feb 6, 2018 | 07:35 AM
SQuaLZ's Avatar
SQuaLZ
It is a pretty damn big job. Hence why it's the only part of my exhaust I haven't touched yet.
What noises are you hearing? How are you diagnosing this?
Old Feb 6, 2018 | 07:36 AM
travlee's Avatar
travlee
Master
the install is a PITA, and the gains you get are minimal for the labor intensive swap
Old Feb 6, 2018 | 08:15 AM
gotama's Avatar
gotama
This is how it sounds like.
Seems like a ratting heat shield. I have no idea how to diagnose these noises. Does anyone have a procedure how I should tackle this ? Because I don't know how to find from where it is coming from. I assume its related to exhaust because the noise isn't continuous but does it at different rpm's. I was blaming the headers because its the only thing that I have oem stock. I'm using Motordyne TDX v2 exhaust and the Motordyne ART pipes instead of the cats.
Any ideas ?
Old Feb 6, 2018 | 08:27 AM
travlee's Avatar
travlee
Master
my bet is the drivers side heat shield is too close to the art pipe. crawl under there and see how much room you have, i had to bend mine with a pry bar to give it room. another thing to check it to see if it is hitting on the m brace, mine was and all i did was wedge a piece of exhaust hanger rubber between the piping and brace
Old Feb 7, 2018 | 01:34 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
All I did was listen to Justin Timberlake, take off the old, and put in the new.. Easy peasy Lemmon squeezy.
Old Feb 8, 2018 | 10:34 AM
sithlordsoup's Avatar
sithlordsoup
Kind of Sounds like a heat shield vibration, how difference is the noise versus driving on the road?
dwnshift
Dec 17, 2004 07:26 AM
ssk0771
Dec 14, 2004 11:06 AM
NOBI
Aug 9, 2004 03:53 PM
zogan
Jun 12, 2003 08:56 AM
