2004 Window Motor running
Old Feb 19, 2018 | 11:02 AM
Michelles350z's Avatar
Michelles350z
Default 2004 Window Motor running
I have a 2004 Z - and the driver window motor will not stop running unless I take the door off and disconnect the switch. After reconnecting it, the motor works and the window will go back up, but the motor keeps running again. So the motor works to some extent - it just keeps running. Is this just a switch or a relay?
Just curious if anyone else has had this issue and how they solved it.
Thanks!
Old Feb 19, 2018 | 04:40 PM
Atreyu'z 350's Avatar
Atreyu'z 350
You can try the reset procedure, and if that doesn't work, I would look at the switch next..
http://www.nicoclub.com/service-manu...pe+Roadster/GW
Old Feb 20, 2018 | 05:13 PM
Dontmocme's Avatar
Dontmocme
Had the problem last week on my passenger side. The limit switch (in the widow motor) went bad and had to replace the window motor. 35$ on Amazon I had a 04 so had to buy one with the button on the motor so doing the learning procedure
Old Feb 21, 2018 | 12:58 PM
zakmartin's Avatar
zakmartin
For what it's worth. If you want to do your own diagnostic before you buy a part...
Edit:
For reference, here's the sticky thread discussing the issue.
jeffw
Dec 27, 2019 07:25 AM
Junkster
Apr 30, 2011 03:43 PM
last letter
Sep 22, 2010 12:01 PM
ZeroFear
Nov 20, 2008 04:09 AM
civic4982
Sep 24, 2008 04:40 PM
