Seam Sealer for floor pan
Old Jul 22, 2018 | 02:41 PM
CruZin03's Avatar
CruZin03
Question Seam Sealer for floor pan
Hello, I just signed up today.
Can someone tell me what seam sealer is used under the floor pan, above the catalytic converter? My 2003 350z Touring, had a clogged converter. I removed the exhaust system cat back. The seam sealer above cats, turned brown, (was white), and some chunks fell out from the excessive heat. Before I install the Berks free flow cats and Invidia exhaust, I will scrape out all sealer that turned brown, and then put on new sealer.
Thanks
Old Jul 22, 2018 | 02:49 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Dont know why you would go through all that trouble but you can get 3m seam sealer. I wouldn't imagine the exact same product Nissan used back in 03 on an industry level would be available in a consumer package.
Old Jul 22, 2018 | 02:57 PM
CruZin03's Avatar
CruZin03
Some chunks fell out. I searched for seam sealer online. But couldn't find one stating how high a temp it can take.
Old Jul 22, 2018 | 03:02 PM
dboyzalter's Avatar
dboyzalter
If it worries you I would just use high temp rtv silicone, it would serve the same purpose. Think they are good for 700 degrees or so.
Old Jul 22, 2018 | 03:05 PM
dboyzalter's Avatar
dboyzalter
I used 100% silicone from the home depot on my fenders once I rolled them to keep moisture and salt out. Its held up well.
Old Jul 22, 2018 | 03:08 PM
CruZin03's Avatar
CruZin03
Thanks dboyzalter, I'll probably try that.....
Old Jul 23, 2018 | 12:34 PM
icer5160's Avatar
icer5160
Yikes, are the CAT heat shields missing? I would definitely re-install some kind of heat shielding once you have things sealed back up. I know people have complained about vibration noise from the OEM heat shield there, but this can be easily mitigated.
-Icer
Old Jul 24, 2018 | 03:29 PM
CruZin03's Avatar
CruZin03
The Cat shields were on.
When I pulled in my driveway, white smoke was coming out from the left cat area, It smelled a little like electrical fire and the interior smelled like ammonia. I lifted the hood and the smoke was coming up from the back of the motor.(cat).
I used a HF laser thermometer. The front of the pipe on the left cat was 958*. The pipe at the rear of left cat was 500*. After about 20 minutes, I checked the carpet under the 2 floorrmats the previous owner had on the drivers side only. The temp of the carpet was 186*F.
When I removed the the left cat, parts fell out of the inside.
After cleaning with rubbing alcohol, there were 4 spots it burned up or fell out at, so I used High Temp Refractory Cement. Good for 3000*F.
The car only has 49,000 miles on it.
Old Jul 24, 2018 | 10:12 PM
icer5160's Avatar
icer5160
Whoa! So the CAT essentially self-destructed. Crazy temperatures!
-Icer
Tim Mahoney
Feb 16, 2007 09:41 AM
HockeyZ39
Apr 6, 2006 02:51 PM
DeZigner
350Z Roadster
Nov 14, 2004 06:29 PM
buzzard
Oct 11, 2003 05:00 AM
