Seam on Top Opening Up
Old Oct 17, 2004 | 11:43 AM
DeZigner's Avatar
DeZigner
Question Seam on Top Opening Up
A few days ago I noticed that a seam in the top of my Roadster is opening up. It's in the back top corner of the passenger side (I tired posting a photo, but no matter how small I make it I get the message that it's too big). It's not a stitched seam, but what appears to be a glued seam. Has anyone else noticed this.
It's a 2004.5 model that I have had for 7 months (9,000 miles).
Dezigner
Old Oct 17, 2004 | 02:42 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Same this happened to mine a few months ago but mine started to seperate at he last strut bar on the drivers side coner. Brought it to the dealer and they replaced it (after a fight). Mine was a '04 and about the sameamount of miles. Some FYI's:
1. Call NNA and open a case before you take it to the dealer
2. Don't let the dealer try to talk you into having it repaired first. Insist on having the top replaced.
Old Oct 17, 2004 | 03:39 PM
DeZigner's Avatar
DeZigner
Thanks for the advice. My one fear is how well does a replacement fit? How is yours?
And what number do you recommend for NNA?
Thanks
Old Oct 18, 2004 | 01:05 AM
ragtopz's Avatar
ragtopz
after they changed out my top, i get a wind whistle behind my head where the top meets the body. i took it in and they told me it was normal. i gave up for now because it isnt so bad.
Old Oct 20, 2004 | 04:26 AM
Ivey's Avatar
Ivey
Had my top and frame replaced several months ago due to holes forming and seam split. New frame and top fit well but had lots of wind noise on the driver side. Turns out a tension cable was not attached correctly and you could actually lift the top up from above the drivers side window and look into the car. Took it back and had the cable re-attached - fixed the problem. If yours makes too much noise check the tension of the top to the frame and make sure it is tight. No problems to report with the quality of the new top or frame....yet
Old Oct 20, 2004 | 07:25 AM
ragtopz's Avatar
ragtopz
i will try to see if i can lift up my top from the drivers side. thanks ivey.
Old Oct 20, 2004 | 09:00 AM
maxpowers's Avatar
maxpowers
I had the material part of my top replaced.
I found a place the specializes in convertable tops first, then when to the dealer and asked them to outsource it to them.
It took three days but they did a perfect job. I think the key to this repair is who the dealer outsources it too.
Old Oct 20, 2004 | 09:14 AM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Finally got back on the site.
The top replacement is perfect. No problems with it whatsoever.
NNA phone is 1-800 Nissan 1
Old Oct 20, 2004 | 03:46 PM
DeZigner's Avatar
DeZigner
Thanks for all the info. Now comes the hard part...giving up my Z for a few days to get the top fixed : (
Old Oct 22, 2004 | 01:05 PM
sluggoZ's Avatar
sluggoZ
maxpowers....The BEST advice...makes a lot of sense!! Get the pro specialists to do the job.
Old Nov 14, 2004 | 06:29 PM
jam350's Avatar
jam350
My 2004 ZR developed the customary pinholes in the top around the curve in the main brace on the passenger side at ~9 months. When I reported it, my dealer offered to replace it before I could ask, and the new redesigned top's been trouble-free so far.
A separating seam may be a different problem -- hopefully not a harbinger of things to come in the 2005s.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
