Thoughts on new wheels?
Old Oct 9, 2018 | 12:47 PM
Spike100's Avatar
Spike100
That will look good. If you get "too flush" in the front, you spray debris along the doors.
Originally Posted by Goodolejim
I have a 08 350, only done tint and blacked handles/emblems. I just bought the attached wheels 18x9 +25 offset all 4 with 255x40x18 rear and 245x40x18 front. Just looking for opinions on them. Bridgestone patenza rear and nexen in front.
Old Oct 9, 2018 | 01:36 PM
Spike100's Avatar
Spike100
Here is a picture of my front 8.5 x 18" +25 mm offset wheels. To me, the fronts are a little "too tucked." But, I'm getting used to them (and more accepting).
Your 9 x 18" +25 mm offset wheels will protrude another quarter inch and will look better.
Old Oct 12, 2018 | 02:21 PM
Goodolejim's Avatar
Goodolejim
I put 2mm spacers in the back an just barely have enough stud left. I checked out the eibachs and will probably get those. Thank you for the advice and also for the installation connect.
Old Oct 12, 2018 | 04:12 PM
Heel Til I Die's Avatar
Heel Til I Die
You may want to install some extended studs if you're not getting enough thread on them. If you don't have a press, it's a pretty easy swap if you've got a hammer and some washers.
Old Oct 12, 2018 | 04:38 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Need to put lowering springs now, how do they look?
Lowering isn't going to help much. 255s in the rear are too short by 0.65" - that's significant. Does your car have VDC? If so, be careful as that too-small size delta F-R could potentially trigger it unintentionally. If no VDC, all good; but I'd encourage you to install the right diameter tires sooner than later.
matt240sx
Mid-Atlantic
Jul 26, 2010 09:55 AM
md1400cs
Jan 30, 2010 03:30 PM
jetjammer
Jul 14, 2003 10:36 AM
Todd@ProDyno
May 12, 2003 07:57 AM
