I was wondering what the voltage was on the clutch button switch that is pressed when the clutch peddle is pressed. And which wire sends power to the switch, and the wire the sends it back into the system.
I haven't had to test this personally yet, but if you have a multimeter it should be pretty straight forward. Which "button" are you referring to? The cruise control switch?
well, the fuse box under the hood behind the battery - you will find fuse 89 - it is a red mini fuse 10amp - that is where the power comes from I believe.
