White smoke from exhaust.
Hello everyone, so I recently purchased a 2005 Nissan 350Z.
after a few days of driving I noticed some smoke coming out the exhaust. Immediately I changed my oil and nothing changed. I took it to the Nissan dealer and they said it’s not a blown head gasket or valve cover, The car doesn’t have a check engine light on either. Can someone please help me? Has anyone had this problem or fimilar with it??
coolant levels have not dropped
oil is it’s natural color no discoloring or milky looks to it?
im going in circles here...
Post up pictures of the 'white smoke' ... white smoke has historically meant coolant in the combustion but if you have excessive moisture in the fuel system it could be a probably cause. Has this just started happening or has it been going on for a while(ie multiple tanks of gas)?
Did the Nissan dealership do a compression test or a leak down test?
A blown head gasket won't necessarily cause water to start mixing with the oil. It's dependent on the location of the leak. If it's a minor leak, you could just be getting small amounts of coolant in the combustion chamber, but no coolant mixing with oil (yet). Again a minor leak won't cause any check engine lights at first. Eventually you might see an O2 sensor trip or temps rise. There's simple test kits you can get that check the coolant system for exhaust/combustion gases.
Here's a good "How to" from Scotty Kilmer:
But based on what you've described, you need to pull the heads and replace those gaskets. While you're getting that done I would also recommend having a good machine shop inspect the heads and have all the valve seals replaced. None of this work will be cheap and I don't know what you've put into the car already, but if you plan to keep it for any length of time or if the car is in very good to excellent condition minus the engine, consider it a peace-of-mind investment.
Good Luck!
-Icer
Good Luck!
-Icer
https://www.youtube.com/watch?v=v0U8Iyf0kk4
Good Luck!
-Icer
Good Luck!
-Icer
A scream'n demon old lady does, one that's hooked on the juice.
It would be an odd happening to blow a head gasket without some form of FI on the VQ.
It's always good practice when buying a used car, especially a sports car, to take it to a relatively competent mechanic for a look-see. I'm not trying to rub anything in here Michael cause this situation does suck ***** for sure. Just some late advice for the next time from one M to another.
Does the car still have CATs? Or is it running test pipes (resonated or not)? The video posted doesn't show that much "white smoke" and it appears to disappear rapidly when the engine is reved. Does the smoke pour out under constant speed/RPM (2000-3000RPM)? Or only when you've been idling for a bit at a stop?
As dnash said, does the smoke go away when the car fully warms up?
Winter is coming and it's not uncommon for moisture/condensation to build up inside the exhaust system. Aftermarket exhausts are more prone to this. There were nights/mornings when I would be sitting at a stop light with the engine still warming up, watching the steam pouring out the back through my rear view mirror.
-Icer
-Icer
-Icer
-Icer
350ZYALATA
Dec 28, 2019 05:22 AM
g35thrilla
Sep 7, 2012 08:29 PM
soccertoad
Nov 28, 2008 08:02 PM
solidsnake
Jun 8, 2007 09:57 AM
