Help! P0024
Old Jan 20, 2019 | 12:23 PM
47chuy's Avatar
47chuy
Default Help! P0024
How do I get rid of check engine light for code p0024? Already replaced camshaft position sensor for bank 2 but still comes back. Started getting a rough idle when in drive and at a stop sign or light.
2008 Auto 350z
Old Jan 21, 2019 | 07:08 AM
Tomek350Z's Avatar
Tomek350Z
Have you checked the power, ground and signal wire from the connector? do a visual inspection on the wires/terminals. It could also be caused by the solenoid itself if it is sticking. The viscosity of the oil could cause this as well, but a longshot, as I would expect other systems that rely on oil would throw DTC's as well.. Did you recently get an oil change done?
Old Jan 22, 2019 | 06:54 AM
munkeymike's Avatar
munkeymike
Where did you get your part from and what brand? Also, just try uninstalling then reinstalling it. Sometimes the connection might have been loose or the sensor not pushed in all the way.
Gcasillas240
Nov 11, 2021 05:53 PM
Emilyb2764
May 27, 2018 03:42 PM
heyitzalex
Feb 26, 2016 03:48 PM
