Need HELP identifying engine part PLEASE
Old Jan 23, 2019 | 12:40 PM
DougEvans's Avatar
DougEvans
Default Need HELP identifying engine part PLEASE
Hello All,
I have an oil leak on the upper passenger side of the engine but I cannot find the part to order a replacement. I have looked through my Haynes repair manual and have searched the internet but cannot find this area illustrated or spoken of anywhere. It's going to be an EASY fix if I can only find out what the heck the part is! Please reference the two photos below.
Thanks in advance!
Doug
Old Jan 23, 2019 | 12:51 PM
LexZ's Avatar
LexZ
PCV Valve?
Old Jan 23, 2019 | 02:17 PM
DougEvans's Avatar
DougEvans
Smile
I believe that's it!! Thanks for the quick response!!!
Old Jan 23, 2019 | 07:01 PM
jhc's Avatar
jhc
General & Tech Moderator
Originally Posted by DougEvans
Hello All,
Thanks in advance!
Doug
Not to put too fine a point on it- your leak starts above the valve, so old hose and loose clamp are suspect. When you remove the PCV valve, shake it. If it rattles the valve is good, just loose. If the rubber hose is old, replace. If good, tighten the clamp. GL!
Old Jan 24, 2019 | 12:31 AM
bad boyz's Avatar
bad boyz
According to the photo looks like the valve is split or broken you can also remove the hose and just replace it with a small filter helps keep oil out if your interested in doing that just let me know and I can get you some more info,or you can go to Youtube and type in 350Z pvc hose delete.
Strumpp
Oct 21, 2013 10:47 PM
layne0
Sep 9, 2013 10:05 AM
sonoriansZ
Jun 7, 2013 08:26 AM
Zhinobi
Oct 17, 2012 03:52 AM
freddys 350z
May 28, 2012 08:19 PM
