My car is overheating
Old Mar 28, 2019 | 11:30 AM
Josue Jr's Avatar
Josue Jr
Default My car is overheating
My car is over heating I don’t know why I change the thermostat on the car I change the radiator I bleed the car but still overheating what’s the next problem please help me out
Old Mar 28, 2019 | 12:35 PM
iideadeyeii's Avatar
iideadeyeii
Not enough info. Why did you change the thermostat?
Old Mar 28, 2019 | 01:44 PM
tcode's Avatar
tcode
A blown headgasket is one possibility too.
Old Mar 28, 2019 | 03:01 PM
Josue Jr's Avatar
Josue Jr
i change the radiator to a Mishimoto and when I changed it it started overheating I burped the car with distilled water no more burps and it’s still over heated changed the thermostat to see if it would help and welp it didn’t
Old Mar 28, 2019 | 03:02 PM
Kevin Skene's Avatar
Kevin Skene
when you crank the heater, is the air hot? If it's not, you still have air in the system.
Z's are difficult to bleed, just takes time.
Old Mar 28, 2019 | 03:05 PM
Josue Jr's Avatar
Josue Jr
where is the best place to bleed from
Old Mar 28, 2019 | 10:46 PM
bad boyz's Avatar
bad boyz
here's a funnel you might try also maybe check your water pump it's internal located in the engine I had to have mine changed out I went through the same exact situation,went ahead and replaced my radiator with the Mishimoto and changed out all my hoses and up graded them and even replace the thermostat as well hope this might help!
Old Mar 29, 2019 | 06:49 AM
travlee's Avatar
travlee
Master
sounds like you took english lessons from tonto
Old Mar 29, 2019 | 07:08 AM
Cracka350's Avatar
Cracka350
Hey, people with bad grammar need love too
When you bleed your system , make sure to hit the upper bleed point. See the manual at the beginning of this vid.
Another thing you could do, (But just do it the right way) is jack the front end way up and keep bleeding the radiator. That worked for me.
Old Mar 29, 2019 | 08:23 AM
iideadeyeii
Change back to oem radiator. IDK why people swap and think it's so much better. There's def air in the system
Old Mar 30, 2019 | 06:40 PM
onevq35de's Avatar
onevq35de
[QUOTE=travlee;10988775]sounds like you took english lessons from tonto
Old Apr 1, 2019 | 04:45 PM
jellofuel's Avatar
jellofuel
+1. You wan to jack that front end up, crank the heat in the car, and burp the system. Burping this system is notoriously time consuming, and this method seems to work best.
Old Apr 9, 2019 | 05:53 PM
jimbucks's Avatar
jimbucks
Just because you replaced the thermostat doesn't mean the new one is any good. Try taking out the thermostat. Are you sure the car is overheating, rather than the temp gauge malfunctioning? If the water pump has failed, this could be the problem.
username
Dec 11, 2008 07:00 PM
VERTZ
Oct 8, 2008 11:16 AM
joshp214
Jun 5, 2006 09:40 AM
350zbiturbo
May 30, 2006 04:48 PM
koolzero
Feb 26, 2005 11:39 AM
