Sponsored by:
Sponsored by:
Change to kinetix????
Old 04-20-2019, 05:41 AM
  #41
Mr600r
Mr600r's Avatar
Nothing I caped it off, I’m thinking I may have a vacuum leak add well. I don’t see another spot/hose for it to connect.
I do have the oem TB ported 5 mm I didn’t check to see how the Mate is, good idea I’ll check it out now.
I didnt use any sealer on gaskets, they are cork gaskets think I should remove and seal??
Something is off, few times I’ve hit it and wow, pulls harder than ever, others just feels very lazy........
help!
Originally Posted by DarkZ03
What's on the 3rd port?
Old 04-20-2019, 06:25 AM
  #42
Mr600r
Mr600r's Avatar
😲😮😳 holy crap!! Maybe with heat and over night gaskets seals better or something, also did TB relearn
And wow today it’s whole diff car. Top end is just silly
slightly less low end but not dramatic, what a diff from last night and today. Very happy with the intake
RobPhoboS (04-21-2019)
Old 04-21-2019, 09:41 AM
  #43
DarkZ03
DarkZ03's Avatar
Glad to hear it's working out, the cork is ok. I'd probably change it out for boosted applications though.
Old 04-22-2019, 01:40 PM
  #44
Mr600r
Mr600r's Avatar
Dam you about dead on !
View this post on Instagram
Originally Posted by jellofuel
Awesome! I'm thinking it will be between 285 - 295 whp.. I think the Velocity doesn't make as high peak whp, but does sustain that power higher into the RPM range than the DE plenum & spacer. It all comes down to the tune, though your build reminds me of Alex Refro's build, he dyno'd 304 whp with an Admin intake, and Velocity manifold. (think he put a velocity stack onto his intake as well)
The following 2 users liked this post by Mr600r:
jellofuel (04-26-2019), RobPhoboS (04-22-2019)
Old 04-22-2019, 02:50 PM
  #45
RobPhoboS
RobPhoboS's Avatar
Excellent !
I'm still waiting for my one to arrive in the UK
It looks like you're revving pretty high, have you got any supporting parts for that ? (as I assumed you're a DE as well)
Old 04-22-2019, 07:13 PM
  #46
Mr600r
Mr600r's Avatar
The only supporting part I have is rev up oil pump, all other internals are oem...... I’m not even sure what RPM to shift at for maximum MPH/ET. Moncef said all the way to 7500, but I don’t want to grenade the engine lol. I was planning on shifting right at 7-7100 rpm (only At track). What do y’all think best RPM would be? Also is it the connecting rod bolts that are weak? If so can oil pan be removed and bolts be swapped for safer operation to 7500?
Originally Posted by RobPhoboS
Excellent !
Old 04-22-2019, 08:11 PM
  #47
DarkZ03
DarkZ03's Avatar
Yeah you need rod bolts to stay on the safe side if you have a DE
Old 04-22-2019, 10:04 PM
  #48
RobPhoboS
RobPhoboS's Avatar
It's the same as me then, my one is limited to 7k at the moment.
I was informed not to just put new rod bolts in, however I'm not a seasoned engine builder so I don't know if that's correct.
Hopefully someone can say.
Old 04-22-2019, 11:02 PM
  #49
DarkZ03
DarkZ03's Avatar
According to Nismo you can just add their bolts and pump and rev higher. I am not a seasoned builder but I am a mechanic and on big diesel engines they would inspect the main and rod bearings and put them right back in if nothing was wrong with them, hopefully someone that has more experience on this engine can chime in.
Old 04-23-2019, 12:53 AM
  #50
RobPhoboS
RobPhoboS's Avatar
That's good to know, I might try and ask around as well (although I'm buying new bottom end components anyway but it's interesting to know!).
Old 04-24-2019, 05:29 PM
  #51
jellofuel
jellofuel's Avatar
Originally Posted by Mr600r
Right?! Congrats on the numbers! I saw the dyno sheet on Facebook, that's an impressive power curve, it doesn't drop off at all up high. You can safely rev to about 7200-7300 or so.
Old 04-25-2019, 06:00 AM
  #52
Mr600r
Mr600r's Avatar
Thank you for the compliment! I’m with you on that rpm to shift at, Ive only taken it up to 7500 rpm a few times.... man that is freaking addicting!!! The sound the engine and intake make is insane!! Literally screams lol, I’m VERY happy with the outcome and the kinetix manifold, for those questioning
that manifold, it does exactly what it claimes to do. For me anyway. I’m extremely impressed, what I’s also impressive
is the low end gains, lost zero anywhere on the graph.
jellofuel (04-25-2019), RobPhoboS (04-25-2019)
Old 04-25-2019, 06:11 AM
  #53
RobPhoboS
RobPhoboS's Avatar
See, we said it would bud.
Now I'm just waiting for my one to show up !
Hopefully it arrives the end of next week.
My one had better make some more poke too !
Old 05-13-2019, 01:04 AM
  #54
RobPhoboS
RobPhoboS's Avatar
Yey, it arrived on Friday!
Remap on the 30th, will dyno/remap first with how it is now, then fit the Z1 intake and dyno/remap again.
I followed the instructions and left their gaskets on and removed the oem ones. Stupidly I had bought an Motordyne Aramid gasket for it though, doh.
Im not into chrome stuff or engine bay tarting up but you know what, it looks quite nice under there.
Old 05-13-2019, 08:05 AM
  #55
Desert Z
Desert Z's Avatar
Let us know your results!
RobPhoboS (05-13-2019)
Old 05-13-2019, 10:10 AM
  #56
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Hats off to you!
Thank you for doing the research - in for results!
Old 05-14-2019, 04:01 PM
  #57
jellofuel
jellofuel's Avatar
Looks good! I know the Z1 intake and Velocity plenum make good power together, and I hope you're happy with the results
Old 05-15-2019, 01:31 AM
  #58
RobPhoboS
RobPhoboS's Avatar
Cheers guys, just remember my numbers will look potentially far lower than what you or anyone else gets
It's a brutal dyno but I use the same one for consistency
Old 05-15-2019, 07:10 AM
  #59
bealljk
bealljk's Avatar
I think the bigger concept is the change in power between the two setups.
RobPhoboS (05-16-2019)
Old 05-15-2019, 04:52 PM
  #60
Conway_160
Conway_160's Avatar
Looking good, looking forward to see what the result are.
Quick Reply: Change to kinetix????
