2006 Nissan 350Z Coupe Front bumper assembly
Old Apr 25, 2019 | 11:27 AM
wzrdstrm's Avatar
wzrdstrm
5 Year Member
Default 2006 Nissan 350Z Coupe Front bumper assembly
Bought a Z from a police auction, while replacing the headlights I noticed I did not have the ten or so bolts under the bumper.....it seems to be missing a piece. All there is holding the bumper on is the two bolts on the right and left sides to the fenders, one bolt on each side to the light and the plastic plugs under the hood. Need to know what the bracket is called that attaches the lower portion of the front bumper. I see there is some broken plastic pieces that extended out from the radiator housing. Any thoughts?
Old Apr 25, 2019 | 11:37 AM
coletrickle74's Avatar
coletrickle74
There should be an under shroud. It goes from the front bumper and covers the entire engine. Z-Speed makes a good aluminum option instead of going with the cheap plastic OEM one.
Old Apr 25, 2019 | 12:14 PM
wzrdstrm's Avatar
wzrdstrm
5 Year Member
Thank you!
Old Apr 26, 2019 | 02:03 PM
icer5160's Avatar
icer5160
The broken plastic pieces that extend out from the front radiator shroud are probably the pieces mentioned in this diagram (21469M/21468).
The only other large plastic pieces behind the front bumper are the ones attached to the crash bar. See 62080P/Q in the diagram.
Good Luck!
-Icer
Old Apr 28, 2019 | 09:25 AM
wzrdstrm's Avatar
wzrdstrm
5 Year Member
looks like I'm missing 62090, you have have a print for the under engine cover to bumper?
Thank you for you time....
Old Apr 28, 2019 | 09:27 AM
wzrdstrm's Avatar
wzrdstrm
5 Year Member
and possibly 62673/4P
Old Apr 28, 2019 | 09:29 AM
wzrdstrm's Avatar
wzrdstrm
5 Year Member
Very positive he hit the front end, no radiator damage, well, bad that I can see, front fenders were repainted and not in the right position, off by n 1/8 on the top near window and door on both sides. Guess he pulled them off, paint was dripping in some spots, not bad, but color is dull also....arrrg... just need to get it ready to sell!!!
Old Apr 29, 2019 | 12:14 PM
icer5160's Avatar
icer5160
You can pull up all the diagrams on nissanpartsdeal.com , that's where I got these.
Good Luck on fixing her up!
-Icer
ProPartsUSA
Suspension
Jun 19, 2013 01:55 PM
