Clutch pedal not working
Old Jun 20, 2019 | 10:40 PM
Xxx33's Avatar
Xxx33
Default Clutch pedal not working
I replaced my clutch everything went good, next day my clutch pedal just sticks to the ground I replace the master and slave worked fine fast forward about a month my clutch pedal begins doing the same thing but its only on a long drive it'll come up halfway and I have to pull it up with my toe I had to drive it like this on the way home the next day I turn the car on and it comes up normally until I drive it a distance just suddenly stops working when im at a stop and the car is still. I don't know if this has anything to do with it but if I turn the A/C on and I'm just sitting there for a bit and drive off it instantly makes the pedal come halfway up.
Old Jun 21, 2019 | 05:59 AM
iideadeyeii's Avatar
iideadeyeii
Boiling clutch fluid. This happened to my on a dyno.
Old Jun 21, 2019 | 07:18 AM
masterjr33's Avatar
masterjr33
bleed/change the clutch fluid.
and check for a way to insulate it from the heat .
guessing you have aftermarket exhaust parts. or aftermarket clutch line.
or something routed incorrectly.
Old Jun 21, 2019 | 07:33 AM
tmdz's Avatar
tmdz
Did you replace the clutch hose as well? Stainless steel with some type of heat shield is strongly recommended for the Z.
Old Jun 21, 2019 | 10:11 AM
Mully's Avatar
Mully
Mine was getting stuck half way down after a clutch, slave, and SS line (I insulated it) change even with DOT 4 fluid. It turns out that the clutch pedal just needed to be adjusted. You can read how here: http://www.jimwolftechnology.com/wol...TSPECSHEET.pdf
After I adjusted it I've had zero issues. Hopefully it works for you as well.
Old Jun 21, 2019 | 10:50 AM
Kevin Skene's Avatar
Kevin Skene
This. Don't spend money when you don't have to. Make sure your pedal is adjusted so that it's getting it's full throw.
jarrodh77
Interior
Nov 28, 2012 06:13 PM
nick731
Jun 12, 2012 09:56 AM
chad_everson
Interior
Nov 1, 2011 09:21 PM
yiii
Jun 17, 2009 04:25 PM
trey.hutcheson
Aug 6, 2006 06:25 PM
