EMUSA Lower Control Arms Install
Old Jun 22, 2019 | 11:24 AM
fiddy_sent's Avatar
fiddy_sent
Default EMUSA Lower Control Arms Install
What's up bros! My lower control arm bushing were completely shot and I didn't feel like going through the hassle of replacing just the bushing so I tested out some EMUSA lower control arms with poly bushings, so I did a little review/ install for your guys. I would definitely recommend them if you guys need to replace your bushings or just want a better drive. Enjoy!
Old Aug 16, 2020 | 12:29 PM
ajnashmd's Avatar
ajnashmd
How are they holding up? is it worth taking the risk on these or is it another ebay special?
Old Aug 19, 2020 | 07:24 AM
Notaz's Avatar
Notaz
I know this is an old thread that was brought back from the dead. However this came up on the first page of Google. That's the only reason I'm answering.
I have had the emusa front arms for 5 years now. Car is modified and sees a lot of spirited street driving and strip use.i have coilovers installed with about a 2inch drop.
These arms have held up to the abuse surprisingly well for the money spent. The bushings are starting to get a bit worn but still are good enough. Honestly I am going to buy another set to replace them.
i haven't had any bending or any moments that make me think they are unsafe. imo they are worth buying.
Old May 29, 2021 | 08:35 AM
ajnashmd's Avatar
ajnashmd
Thank you for Chiming in! I still haven't pulled the trigger on these and was about to just get OEM ones from 1Aauto or something like that.
Old Jun 1, 2021 | 06:17 AM
iideadeyeii's Avatar
iideadeyeii
I've had an Emusa wastegate(tial replica) on my z for 5ish years. No issues with the ebay part either.
Old Jun 4, 2021 | 07:14 AM
Sundown72's Avatar
Sundown72
The set I received had the incorrect taper cut into the arm. This meant the Nissan cone spacer wouldn’t seat properly and was bearing just on the rim, and not on the face. This in turn resulted in play in the front lower ball joint/taper sleeve area and 1) the car couldn’t then be aligned properly and 2) it wasn’t risk I was willing to take on. I posted a PSA thread about it with some photos. Search for EMUSA LCA PSA and you should get a hit.
I returned mine and received a refund. I’m on stock + whiteline now, and very pleased, much safe.
Douglas Choi
Suspension
Nov 25, 2017 06:37 AM
fourtwenty916
Aug 28, 2014 12:51 AM
vaxe21
May 23, 2013 11:27 PM
DEMoLITIoN
Nov 27, 2012 09:48 AM
mdd
Mar 10, 2012 05:57 AM
