HR Swap Q
Old Sep 17, 2019 | 07:56 AM
alex20cast's Avatar
alex20cast
Default HR Swap Q
I was wondering if it’s possible to swap an HR motor with ALL electrical components from a donor car into a 03 DE 350Z? I mean does everything fit correctly(PNP)?Thanks
Old Sep 17, 2019 | 08:21 AM
bealljk's Avatar
bealljk
nope
Old Sep 17, 2019 | 08:38 AM
travlee's Avatar
travlee
Master
guess the search function is broken
Old Sep 17, 2019 | 08:51 AM
alex20cast's Avatar
alex20cast
Don’t the HR and DE chassis have the same mounting points? Can’t you swap the ECU, BCM, IPDM, etc....and all the harnesses that go with them? Then swap in the HR engine, CD009-trans, and HR steering rack? And if you don’t need to fabricate anything...isn’t that pretty much PNP?
Old Sep 17, 2019 | 09:06 AM
travlee's Avatar
travlee
Master
nope
Old Sep 17, 2019 | 09:11 AM
alex20cast's Avatar
alex20cast
Originally Posted by travlee
nope
Why nope?
Old Sep 17, 2019 | 09:19 AM
terrasmak's Avatar
Huge project, simple solution is a donor car to swap everything over
Old Sep 17, 2019 | 09:21 AM
alex20cast's Avatar
alex20cast
Yup..that’s what I meant. Just look for a salvaged HR 350 and swap everything would work. Correct? Isn’t the only difference(dimension-wise) with the DE and HR is the height right?
Old Sep 17, 2019 | 09:35 AM
terrasmak's Avatar
Core support and hood.
Old Sep 17, 2019 | 09:39 AM
bealljk's Avatar
bealljk
nope...
many many differences … if you want HR power levels on your DE get cams, intake, exhaust, and a tune. If you want more power than an HR put a turbo or a supercharger and a tune. Either will be less headache and will be less expensive.
but don't listen to us … search up and down in this forum and on the internet and see how many people ask this same swap question and see how many times it's been done.
Old Sep 17, 2019 | 09:50 AM
alex20cast's Avatar
alex20cast
Originally Posted by bealljk
nope...
I just don’t hear any explanation of why? Everyone just says “no” or “it’s not worth it”. I UNDERSTAND that it’s not worth swapping to a slightly better HR engine with minimal gains, but if you get a donor car....what problems would you run into doing the swap?
Old Sep 17, 2019 | 10:33 AM
bealljk's Avatar
bealljk
I'm no expert but the DE and HR are very different engines and different chassis. And sure, you can bring over all the computer boxes from a HR and put them into a DE but there are many systems that 'talk' to each other in each respective chassis that aren't going to be compatible.
Think of them as two different cars - You couldn't take all the engine, computers, wiring, etc out of a chevy corvette and install them into dodge challenger and expect them to work - despite they are both rwd, 8 cylinder, high-performance cars.
I would invite you to read-up on other people who are interested in this swap and see how far they've gotten before you start buying parts.
Old Sep 17, 2019 | 11:08 AM
alex20cast's Avatar
alex20cast
There are a couple of people who have swapped in an HR engine but they used the engine harness and ECU from the HR but cut into the harness to incorporate it into the dash DE dash harness to communicate. I was wondering if instead of cutting into the harness...you could just swap all the wiring. Aren’t the DE and HR Zs much more similar than a Vette and Challenger?
Old Sep 17, 2019 | 11:09 AM
travlee's Avatar
travlee
Master
search and you will find the answers
Old Sep 17, 2019 | 11:11 AM
alex20cast's Avatar
alex20cast
I have searched...that’s why I’m here asking here.
Old Sep 17, 2019 | 11:28 AM
travlee's Avatar
travlee
Master
really.... 2 seconds and i found these
Old Sep 17, 2019 | 11:34 AM
alex20cast's Avatar
alex20cast
You act like I haven’t seen those posts...I just haven’t found the answer in any of the posts.
Old Sep 17, 2019 | 11:39 AM
travlee's Avatar
travlee
Master
because its a rare occurance
Old Sep 17, 2019 | 11:43 AM
alex20cast's Avatar
alex20cast
Of course I know that...so can you help or share some knowledge?
Old Sep 17, 2019 | 11:57 AM
travlee's Avatar
travlee
Master
then do more reading,
