Nissan 350z 2007
Old Nov 30, 2019 | 07:30 PM
Brayanblanco22's Avatar
Brayanblanco22
Default Nissan 350z 2007
Hi guys i’ve been dealing with this issue as long as almost a month ago. My car turns off while driving, i dont find anything similar on the internet.while driving “TCS OFF” and “SLIP” turns on, the car has a loss of power, under 1000 rpms and it doesnt go more than a 1,000 rpm. I stop, turn off the car then turn it on and it drives normally, then whenever the car wants it happens again..i changed the 2 camshaft sensor, nothing changed. I changed the sensor of the exhaust valve timing (solenoid) for like 2 weeks the car was good and then again the same problem.. im gettin crazy, my car has straight pipe so my service engine light is always on..i really need help. When i plug the computer it only shows a code from the timing valve. Someone told me that maybe i have to change the valve instead of only the sensor. Pls need help ASAP
Old Dec 1, 2019 | 06:01 AM
813_350Z's Avatar
813_350Z
Is your CEL on? I'd find it hard to believe that TSC and SLIP would illuminate under these conditions and a DTC not be present.
Old Dec 1, 2019 | 06:12 AM
Brayanblanco22
yes bro the CEL is on, but i have straight pipe, the code says that has to do with the exhaust valve timing control
Old Dec 1, 2019 | 06:20 AM
dkmura's Avatar
dkmura
General & DIY Moderator
What exactly is the code?
Old Dec 1, 2019 | 06:28 AM
Brayanblanco22
i don’t know exactly the code, but i changed the sensor, a person told me that it could be the complete valve that mayebe is damaged inside
Old Dec 1, 2019 | 06:45 AM
dkmura's Avatar
dkmura
Here's the problem with just taking somebody else's word on this. Without knowing the code, you won't know what the diagnostic system is flagging for this particular issue. Sometimes there are multiple possibilities that you don't explore. It also handicaps you when you SEARCH on this board (or any other source) for solutions to your problem.
Sometimes it can be as easy as changing the brand of a component for another (maybe OEM) part. Sometimes there are cascading issues that are causing your Z to enter limp mode. What ever it is, be aware that limp mode is usually triggered when the diagnostic system finds a code that could compromise your safety or seriously damage the drivetrain.
Don't be a trained monkey and start throwing parts at the car. If you're unwilling or unable to get a diagnostic tool to repair your Z, just take it to a qualified Nissan tech in your area and get it done right the first time.
Old Dec 1, 2019 | 07:57 AM
Brayanblanco22
brother my family mechanic diagnosed it, and he says its the exhaust valve timing control. We changed the sensor, but he said tha maybe has internally damage.
Old Dec 2, 2019 | 01:25 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Well, it sounds like the problem has been diagnosed and in good hands.
Old Dec 4, 2019 | 06:48 AM
Brayanblanco22
nope, now it has a weird code, it about the ABS.
Old Dec 4, 2019 | 06:56 AM
travlee's Avatar
travlee
Master
guess your family mechanic sucks then
Old Dec 4, 2019 | 07:27 AM
813_350Z's Avatar
813_350Z
Well, what does it say then?
Old Dec 5, 2019 | 07:03 AM
epenbecks's Avatar
epenbecks
what exactly is the code?? you can't just say its exhaust valve or abs. people can't help you if you just guessing like that
Old Dec 5, 2019 | 01:06 PM
Bak3rme's Avatar
Bak3rme
at first i like like ok OP needs help, then now sounds like a troll post.
check ur battery terminals
Old Dec 5, 2019 | 03:06 PM
Heel Til I Die's Avatar
Heel Til I Die
It's a shame when the inflection of sarcasm is lost on the internet.
Old Dec 5, 2019 | 04:52 PM
Brayanblanco22
not a troll post brother, its a weird problem. My mechanic was trying to fix it but i was asking in here to see if someone had my same issue to not loose time. Ok bro? U got it?
Old Dec 5, 2019 | 08:33 PM
813_350Z's Avatar
813_350Z
"Ok bro? U got it?"
Old Dec 7, 2019 | 06:15 AM
Brayanblanco22
"Ok bro? U got it?"
u got a problem?
Old Dec 7, 2019 | 06:36 AM
travlee's Avatar
travlee
Master
Sounds like you do. Short man syndrome?
Old Dec 7, 2019 | 06:41 AM
813_350Z's Avatar
813_350Z
No, but it sounds like you do. Do you want help with this issue or not? Because if you keep up with the "attitude" that I, and I am sure others, are getting from the tone of your responses then you and your "mechanic" are going to be figuring this issue out yourselves because no one here is going to entertain that.
Old Dec 9, 2019 | 07:57 AM
epenbecks's Avatar
epenbecks
