Sound coming from air on?
Old Dec 2, 2019 | 02:54 AM
SenpaiNodusMe's Avatar
SenpaiNodusMe
Default Sound coming from air on?
Hello, it's me again.
I had this sound awhile ago but it hasn't happened since then. I'm pretty sure it only happens when it gets cold, It starts up when I wait about 2 minutes for my car to warm up then it starts doing this then goes away after about 5-10 minutes of driving it.
I don't have the air on full blast, only on the lowest setting. No defrost on, Just the heat a 75 with the air low.
It sounds like it's coming from the heater core, Not really sure.
Anyone have any other ideas?
https://www.youtube.com/watch?v=Ectr...ature=youtu.be
Old Dec 2, 2019 | 03:06 AM
jhc's Avatar
jhc
General & Tech Moderator
Sounds like the AC fan bearings are going, here's how to test-
Put the temp control on hot but the fan off. If you still have the noise you likely have air in the heater core. If not, turn on the fan at the same speed as before and see if noise begins. You should have your answer.
Old Dec 2, 2019 | 03:08 AM
SenpaiNodusMe
Will do,
Would it be necessary to change the bearings ASAP? Or may I wait awhile?
Thanks for the response.
Old Dec 2, 2019 | 08:44 PM
jhc's Avatar
jhc
Originally Posted by SenpaiNodusMe
Will do,
If it is the fan you can run the heat till the fan seizes. The noise usually gets louder until the blower dies, then you change the fan/motor as 1 piece. IF that’s the problem there's no harm in running it till it dies, and it won't cause other problems. Gl!
Old Dec 3, 2019 | 04:07 AM
SenpaiNodusMe
Sweet,
Thank you very much.
Old Dec 4, 2019 | 12:50 PM
SonnyWu's Avatar
SonnyWu
Sweet,
I don't care what anybody says but you're alright with me. LOL
I like some of the songs on your Chill playlist. I actually have a few of the same.
How many miles do you have on the Z? I'm preparing for future fixes.
Old Dec 5, 2019 | 06:51 AM
SenpaiNodusMe
Thanks!
I have about 68,000 miles.
I'm preparing aswell, I plan on getting some coil overs soon!
TURBOROADSTER
Mar 9, 2011 07:57 AM
smcgee1970
Sep 4, 2003 04:15 AM
twinzz
Oct 3, 2002 07:56 PM
