Replace alternator
Old Jan 11, 2020 | 10:09 AM
jaemes's Avatar
jaemes
Default Replace alternator
There is an electrical connection behind the alternator that I can't see very well. Beside the clip-in connection. Does anyone know the configuration of the connection?
Old Jan 11, 2020 | 10:44 AM
813_350Z's Avatar
813_350Z
Hey James. You will need an 8mm for the two small bolts on the back of the alternator This is actually only a bracket and can wait until last. There is also a nut on the back of the alternator for the positive. This is a 13mm I believe. You will need a 14mm for bolt on the front-bottom of the alternator as well as the loooong bolt that allows the alternator to pivot. This long 14mm will require you to remove your rad fans. Don't forget that connector on the back.
If you had asked a day or two sooner I would have taken pics. I just reinstalled mine yesterday lol
Any other questions just let me know.
Old Jan 21, 2020 | 09:20 AM
DeusExMaxima's Avatar
DeusExMaxima
I just did my alternator too. What 813 said is right. Also, there is a hose that is fitted into the bracket behind the alternator. Removing that gives more wiggle room to get to the 8mm nuts and the positive cable nut.
DeusExMaxima
Jan 21, 2020 09:27 AM
AP350z223
Aug 25, 2015 10:48 AM
sry110
Aug 12, 2015 11:13 AM
Clon3
Jun 15, 2011 09:40 AM
