Switch to open 350z hatch from inside: Check out my mod
Old Feb 19, 2020 | 01:46 PM
wahmad350's Avatar
wahmad350
Default Switch to open 350z hatch from inside: Check out my mod
Check out my video to wire a switch to open 350z hatch from the inside (BCM bypass)
https://youtu.be/nOF_JENaO_c
Old Feb 19, 2020 | 04:10 PM
karlt's Avatar
karlt
An option would be to place the switch between BCM pin 30 (the input from the switch above the license plate) and ground. That way you wouldn't be splicing into a battery lead and risking a possible short. For reference, see the bl.pdf section of the Service Manual.
Old Feb 20, 2020 | 04:32 AM
khnitz's Avatar
khnitz
5 Year Member
That's a cool idea. I have a similar trunk/hatch release as an OEM feature on my Passat wagon, for example, and it's convenient.
If I were to do this mod on my Z, I'd probably find another TCS Off switch and install it at this switch blank location, re-labeling it and using it for the trunk/hatch release.
Idea for an accessory switch location in a stock location.
Old Mar 2, 2020 | 12:13 PM
karlt's Avatar
karlt
Originally Posted by khnitz
That's a cool idea. If I were to do this mod on my Z, I'd probably find another TCS OFF switch and install it at this switch blank location, re-labeling it and using it for the trunk/hatch release.
Instead of using a Z TCS OFF switch, try the Power Liftgate Switch from a Nissan Armada. The Nissan part number is 25380-7S200.
Debi60
Sep 3, 2022 01:55 AM
Revived_Signs
Jun 19, 2014 01:12 PM
rolling
Sep 9, 2005 08:04 PM
KONVERTER
Nov 4, 2003 10:01 PM
LBC TRD
Oct 7, 2003 08:44 AM
