Tire questions 295 30 19 & 255 35 19
Old Mar 13, 2020 | 10:49 AM
edp82's Avatar
edp82
Default Tire questions 295 30 19 & 255 35 19
Hey guys, sorry i've searched the forum and i can't quite tell if the above tire combination will keep the VDC in check.... will i be okay with that tire combination?
Old Mar 13, 2020 | 03:09 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
There's a -2.7% difference in height F-R (26.03"/25.97" diameters F-R) which is a bit low and may trigger VDC. ECM is expecting lower wheel speed at the rear (right at 3.0% +/- 0.15% )
With 295/30s, the rear will show rear wheel speeds high, likely enough to trigger VDC.. I'd err towards a 285/35-19 (or possibly 295/35) just to be safe.
Old Mar 13, 2020 | 04:15 PM
edp82's Avatar
edp82
Can you double check the math. I find it to be almost exact heights. The rear being only .3% shorter.
its not 2.7%. It’s .27 of 1 %.
Old Mar 13, 2020 | 04:32 PM
edp82's Avatar
edp82
Old Mar 13, 2020 | 05:14 PM
travlee's Avatar
travlee
Master
I would trust mic on anything tire related.....hell I pm'd him questions with my Corvette tires
Old Mar 13, 2020 | 05:57 PM
edp82's Avatar
edp82
But his math is wrong though. The numbers he provided are not 2.7% different.
Old Mar 13, 2020 | 07:15 PM
MicVelo's Avatar
Ooops, good catch.... yer right, math error... I was looking at the scribble numbers on my napkin where the delta on the standard reference sizes (OE 18s) is -2.7% (averaged between comparison to front or rear) F to R difference and not the sizes you mentioned.
But answer still stands then, even moreso. These tires are almost identically sized diameter wise which means VDC will "TEND" to be even more aggravated because the rear is so close in size when it's expecting somewhere close to a 100:97 ratio F to R. I use the word "TEND" because there are many who run square setups and have no VDC errors and others who so much as deviate by a single size throw codes, lights and limp mode in a flash. I stand by my recommendation in choosing an alternate size that conforms to the 3% algorithm. There really shouldn't be any worry about going to an alternate because width is width.
Old Mar 17, 2020 | 11:56 AM
edp82's Avatar
edp82
Default 275 35 19 & 255 35 19??
hey guys hoping someone could chime in for me..... i recently was going to run a new setup with my rear tire being 295 and the fronts 255.... i've taken the car out to test the drive and i dont particular like the added unsprung weight... it just seems slower to change lanes than i have been use to. My previous setup was a 275r & 245f...
my question is.... I found a very good deal on a set of 275 michelins ... and im wondering if the 275 rear and 255 fronts would be okay to run together...
Old Mar 17, 2020 | 01:57 PM
rustyschopshop's Avatar
rustyschopshop
those widths are what i am using, no issues
abui01
Mid-Atlantic Marketplace
Aug 12, 2011 03:48 PM
mondi
Oct 30, 2007 06:05 PM
tartman
Oct 8, 2007 05:43 PM
youngZ33
Jun 23, 2006 02:07 PM
