Solid LCA bushings on the street?
Old Apr 6, 2020 | 04:21 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
Default Solid LCA bushings on the street?
I couldn't get in the inmer lower control arm bushings and didn't even try to attempt the LCA shock mount bushing. Megan racing bushing (rubber 150% harder than stock) would just not go in straight.
Anywho, have any of you guys run these on the street? I like that they allow flex. I also dont want to blow out anything hitting a pothole. I figure the lower shock one would be ok since the rear shock is solid mounted.
What do you think? Good idea? Bad idea?
Old Apr 6, 2020 | 10:27 PM
terrasmak's Avatar
Compression arm I would go solid. Then the LCA , do either urathane on the shock mount and solid inner or urathane for the whole LCA. I've done this on customers cars, my car has full solid and my moms g has whiteline compression arm bushings I do not recomend after installing them.
Old Apr 7, 2020 | 01:12 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
I'm sorry, I am slightly confused on what you are advising me to do. I already went OEM for the compression arm bushing as I didnt know until yesterday they made a solid, free movement one until yesterday. I didn't want to put poly there because it looks like that bushing needs to flex, A LOT.
The top shock mount is OEM. Are yiu saying the lower shock mount to go poly instead of solid? Why do you say that?
Another question for you: does that inner LCA bushing need to flex? If so why do people put poly in there? I feel the solid would be better since it at least allow the geometry of the arm to move as designed
Old Apr 7, 2020 | 02:31 PM
rustyschopshop's Avatar
rustyschopshop
They don't need to flex only pivot
Old Apr 7, 2020 | 02:49 PM
terrasmak's Avatar
inner Lca and lower shock mount require minimal flex, poly works well. I like solid for the inter and poly on the shock. My car is solid everywhere, the LCA Free floats and makes a ton of noise do to the swaybar endlink offset cause the arm to move. A poly shock mount stops that and adds minimal stiction.
Old Apr 7, 2020 | 04:19 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
Gotcha, thanks for the clarification
kbailey91
Aug 1, 2014 09:52 PM
CptWiggles
Aug 11, 2013 12:23 PM
acke15
Wanted
May 3, 2011 02:46 PM
johnlotusboy
North West
Jan 29, 2010 03:27 PM
