Believe I have a valve cover leak
Old May 18, 2020 | 03:42 PM
ecop_z33's Avatar
ecop_z33
Default Believe I have a valve cover leak
I think my right valve cover gasket is no good as I see leaking all down the right side of the engine. Is this the case or is it something else? If so if someone knws the part numbers needed for both gaskets to complete the job I'd appreciate it. (See pictures I took below).
Old May 18, 2020 | 04:55 PM
813_350Z's Avatar
813_350Z
Just go to Nissan and tell them you need the valve covers for your year Z. Going to set you back a couple hundred.
Old May 18, 2020 | 04:57 PM
ecop_z33's Avatar
ecop_z33
Should I only get the one that’s leaking replaced or both? Left one is spotless.
Old May 18, 2020 | 05:46 PM
813_350Z's Avatar
813_350Z
Might as well do them both while you have it apart. That way you dont have to rip it apart again if the other starts leaking.
Change your plugs while you're in there too.
Old May 18, 2020 | 06:12 PM
BigBlue's Avatar
BigBlue
I had the pass side cover replaced by the dealer a couple of months ago; part comes with all plug tube seals, gaskets etc. and I'd recommend just having the Nissan dealer do it; they did mine pretty quickly, saves a lot of time and the price was fair.
Old May 19, 2020 | 03:35 AM
Jim Stephens's Avatar
Jim Stephens
This is so common they have kit for that. LOL. Do both. Stick with OEM on this replacement.
https://www.z1motorsports.com/cylind...ge-p-7167.html
Old May 19, 2020 | 04:06 AM
Bak3rme's Avatar
Bak3rme
drive side more prone to leak than pass. spark plug #6 seal most likely will give before others. good time to clean it all up. give yourself half day. not a bad job but a lot of things in the way that need to be removed. do spark plugs and take the time to clean out all the oil in ur upper/lower intake plenumn
mcarther101
Jul 16, 2013 10:04 PM
bikinilust
Apr 4, 2012 08:35 PM
Mr_pharmD
Jan 22, 2008 07:12 AM
whitez618
Feb 8, 2005 08:18 PM
