If you have tire pressure monitor, be careful when getting tires mounted/dismounted.
Old Sep 20, 2002 | 08:14 PM
raceboy's Avatar
raceboy
Default If you have tire pressure monitor, be careful when getting tires mounted/dismounted.
Just a quick note, warn your tire installer that you have tire pressure sensors. I had a puncture already and had to have the tire patched at the track. I didn't warn the guy, but luckily he knew about the car and told me that in the future, I should warn tire guys so they don't tear off the sensor. He actually showed me that he uses a different arm on the bead breaker.
BTW, I did see the TPS. It is a little blue plastic piece on the inside of the valve stem and it angles a bit so it lays flat against the wheel.
Old Sep 21, 2002 | 05:25 AM
redlinez's Avatar
redlinez
raceboy,
Were you able to determine if the TPS is mounted the same as a regular valve stem or are the wheels made specificly for them. I'm curious if we can mount the sensors in aftermarket wheels.
Thanks,
Bob
sales@czp
Sep 23, 2019 03:30 PM
ablaine
Nov 29, 2016 10:13 AM
